| Tyre pressures My 1.3multijet mk 2.5 seems to have a lot of wear on the front tyres (especially at the outside edges). I was wondering if the tyer pressures given in the manual were slightly low as the engine is heavier than the petrol versions. The tyre always seemed to be low but the garage said the pressures were spot on. Any suggestions on what I should do - go slower at corners, put more air into the front tyres or get a better brand (year old Continentals). What is the best tyre for my Punto ( a friend suggested Pirrelli) ? Thanks esseffe
| Women drive coupes too | Re: Tyre pressures Have you had the tracking checked as well?
| | #3 | ||
| Re: Tyre pressures If it is just the outside edge, then it sounds like; a) The steering geometry is slightly out, in which case the tracking will need adjusting. However, both tyres would tend not to wear at the same speed, so this may be a sign of deeper trouble within the steering geometry b) you go around corners too fast! If the inside edge is also wearing quickly, then the tyres are under pressure. What do you put in them? About 2.1 bar is about right perhaps?
__________________ Big Northern Monkey No longer a Fiat owner: Audi A2 1.4TDI SE in silver with climate and rear bench seat. A beautiful car. smart city-coupe Mk6 pure in Jack black with grey scordic trim. No mods (even the rubbish standard stereo) | |||
| | yorkshiretb | Marea | 5 | 03-05-2005 22:37 |
| | Steve L | Stilo | 6 | 07-04-2005 23:17 |
| | AIJ29 | Cinquecento / Seicento | 9 | 13-12-2004 13:18 |
| | petoid | Punto | 5 | 23-03-2004 20:04 |
| Panda Fire Tyre Pressures | jbeavon | Panda (Classic) | 2 | 20-01-2004 21:07 |
