The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 30-06-2005   #1
The younger modder's Avatar
Trader Rating: (0)
Talking Mk2 punto 1.2 8v tuneability
Well quick question i was going to put in technical but figure ill get more replys here
so what can be done sensibly to the mk2 punto 1.2 engine apart from exhaust and induction kit can you do mods like on the cinq sporting such as fit a throttle body off a bigger engine etc or is it just things like expensive cams
wayne
The younger modder is offline
Old 30-06-2005   #2
Trader Rating: (0)
Malta
Re: Mk2 punto 1.2 8v tuneability
Unfortunately no, or at least that is what others claim, that the mk2 8v ecu will not "learn" that much so no modding apart from what you mentioned.
If you do not want to put a piggyback (sorry, no remaps for this ecu :'( ) most you can do is lighten the car and lighten the flywheel to achieve high revs quicker.
--- Punto mk2 8v---
*Int & Ext neons**Tinting**Int Alum trim**Momo gear set**Momo pedal set*
*Body graphics**Custom Ice install**Custom A'Pex Integration CAI**Sports exhaust**Racing Seat Belts**Removed seats**Lexan Windows**Weight reduction*
Neo-The Matrix is offline
Old 01-07-2005   #3
Trader Rating: (0)
My uncle builds race engines and he does lightened flywheels etc but one downside to lightening the flywheel is although on flat ground it will give better acceleration it is weaker and can reduce torque for getting up hills etc and in my next car im not lightening it as im having everything such as leather recliners the lot
Im surprised the ecu cant be chipped as the cinq ones can be and i would of thought the ecu would be similar as the mk1 punto
Old 01-07-2005   #4
Trader Rating: (0)
Malta
The engine is similar to that of the mk1 (since it is FIRE), the electronics are totally different.
Yes, a lightened flywheel may reduce torque but 1)if properly done with a not so extreme shave off the torque reduction will be barely noticable, 2)If you can get the revs going up hill will be no problem.
My friend reduced the wieght of his flywheel, not alot but just enough, as regards torque it feels the same, but it is accelerating much quicker.
If I were you I would invest in a piggyback, right now I am looking at the SMT6 and the Greddy E Manage, actually I am almost done on the E Manage cause the car is going to get a turbo.
--- Punto mk2 8v---
Old 02-07-2005   #5
Trader Rating: (0)
GSR can do a lot of work to this engine but as previously said the hitachi ECU has very tight limits. Lowtechguy has been on a quest for some time to find an alternative solution, lots of info on www.clubfirepower.co.uk.
I have heard a lot of rumours from very good sources that the solution will be with us soon, so they havent given up just yet. Once this is solved this engine has a lot of potential and can be tuned fairly cheaply, well cheaper than its 1242 16v cousin.
Things like headwork, exhaust, induction, throttle body, ecu could all be done to a very high standard for under £2k and i'd expect it to run a good 80-90bhp with a similar torque figure.
James
JamesMK2 is offline
PUNTO: Installing an External Head Unit in a Punto MK2 danny bravo I.C.E 10 24-09-2008 20:36
(T) hi i'm new and having problems with my punto mk2 big_caius Punto 7 23-02-2008 12:03
(T) Punto Mk2 1.2 8v Over Revving NEILD Punto 15 06-02-2005 23:40
Boyf's MK2 Punto Sporting 1.2 JoJo1980 Lets Talk FIAT 6 16-11-2004 20:59
(G) punto sporting 1.2 16v mk2 wongy008 Punto 2 13-10-2003 01:55
