Lamps by Post - For all your lighting needs
Thread Tools
Old 07-12-2013   #1
Question Relay buzzing
Hi all I'm new to this found site on google been using it for last 3 weeks trying to sort my daughters poorly punto any help appreciated thanks
Fog lights on with headlights relay buzzing nonstop mechanic changed switch no difference, auto leccy checked all electrics and changed light stalk found nothing wrong I've had all lights off made sure all clean they all work fine fitted new relay all still the same not drive able because lights needed please help thankyou
Eddie1401 is offline Reply With Quote Quote
Old 07-12-2013   #2
Trader Rating: 5
fingers99 has donated!
Re: Relay buzzing
Which relay?
Or, what lights work when/if you unplug the relay?
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 08-12-2013   #3
Re: Relay buzzing
Hi it's the relay in fuse box in drivers side all lights work except headlights when removed.
Likes bomscare liked this post
Old 08-12-2013   #4
Trader Rating: 5
Re: Relay buzzing
Relay buzzes only when dipped beam is on?
M12 fund 20
Old 08-12-2013   #5
Re: Relay buzzing
Hi, it buzzes when lights turned on and engine started any lights on stalk but the stalk is also turning rear fog on when turned to headlights if you press brake pedal it stops buzzing or put handbrake on or turn off lights, when lights off if you indicate either way headlights start flashing as well. Car battery dead at mo cause been messing with it so much I can't check but think this is what it is doing.
Old 08-12-2013   #6
Trader Rating: 5
Re: Relay buzzing
Sounds like a classic earth fault. The problem will be finding where.
M12 fund 20
Old 08-12-2013   #7
Re: Relay buzzing
Thanks for your help, that's what we thought hence auto electrian but with him not finding any faults need to rethink could maybe be something else minor but where we don't no could he have missed a bad earth? Thanks again for replying
Old 08-12-2013   #8
Re: Relay buzzing
Does anybody know all earth points for lights on fiat punto 02 reg? Or which relays are for lights in engine fuse box?
Old 08-12-2013   #9
Re: Relay buzzing
Does anyone know what headlight servo on fiat punto 02 reg is and where I can find it to see if that's the problem for relay buzzing, read some posts on here that said servo problem on there fiat was causing there's to buzz.thanks.
Old 08-12-2013   #10
Trader Rating: 5
Re: Relay buzzing
No such thing as a headlight servo. The brake servo itself has no electric connectors.
Quote Quote:
This is probably the location of the problem. I suspect the relay noise is just a symptom. You might try running another temporary earth for the indicators.
M12 fund 20
Old 09-12-2013   #11
Re: Relay buzzing
Cheers for that it's going back to mechanic tomorrow failing that scrapyard such a shame when car works
Old 18-09-2016   #12
Re: Relay buzzing
Eddie, Did you ever get to the bottom of this?
Trollbooster is offline Reply With Quote Quote
Old 19-09-2016   #13
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Snowboard Slalom Champion, Skate Boarder Champion
Re: Relay buzzing
he's not logged on since 2013 according to his profile.... also they are talking about a mk2 here and not a mk1. from skimming it i would say he had either a faulty earth or the headlight adjuster motor was shorting and constantly rotating (or both).
Whats your problem exactly??
Charmander - Panda Mania 1242 mpi 8v - thread
Unnamed - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT
blu73 is offline Reply With Quote Quote
Old 01-08-2017   #14
Re: Relay buzzing
With the headlamps off, the relay under the dash buzzes and the lights (side & dip) flash. Switch the lights on and it's fine. My daughter used the car to go to Uni and drove it on dipped beam all the time. Now the MoT looms....
The buzzing and flashing doesn't vary in frequency. Swapped the relay out and it made no difference.
Thread Tools
headlight buzzing tony e Car Care 2 17-10-2010 19:42
(T) Buzzing from dashboard. AlanHod Grande Punto 12 10-04-2008 11:09
(T) buzzing markwi Doblo 1 31-12-2007 18:30
(T) Buzzing Dashboard topgazza Punto (Mk2/2b) 0 05-05-2005 20:15
