Another eventful (and very stressful) weekend with the Punto has passed.
Cracked on with checking the valve clearances Saturday, simple enough job after removing air intake, injector plugs, ignition leads and finally the rocker cover
(After checking old photos, that oil feed pipe has definitely gone out of shape, something to worry about?)
Couldn't find my spark plug socket as it had been tidied away with dads endless boxes of odds & ends, which made turning the engine a bit difficult (17mm spanner on the camshaft sprocket) but had to do the same thing last time round so no big deal. (have found it since)
Checked all the clearances with my feeler gauge set, jotted everything down and checked again to be sure (my set only has 0.15, 0.2, 0.3, 0.4, 0.5 and a few other smaller/bigger ones)
Then spent probably an hour trying to remove the first shim in order to measure its thickness. Without the special Fiat tool I was struggling, and after trying every flathead and pry-bar tool I could find, as well as making a custom tool out of an old spanner (as vaguely recommended in Haynes
) which didn't depress the buckets down far enough to remove a shim
I decided to just bite the bullet and unbolt the camshaft so I could just pop out each shim. This involved partially removing the ignition coil pack housing but in the long run was much quicker. I set the engine to TDC for cylinder 1 before doing this, but as you'll learn further on that was a bit pointless....
Anyway after removing each shim and recording the 'stamped' thickness as well as measuring with a set of calipers (sorry no photos) I popped in from the cold for a cuppa and some maths!
Worked out I could get some of the clearances within/closer to spec by swapping around a few shims (cylinder 4 was fine but a couple of other were quite a bit out). At this point I was happy and started to rearrange the shims, and things were going well.... a bit too well.....
I was out to watch Ireland in the rugby that evening so the next day I returned, quite hungover, to re-attach the timing belt and reassemble the engine. It was at this point I discovered to my horror that there were barely any teeth left on the belt! It was nearly a flat bit of ribbon!
Any plans for a nice relaxing Sunday evening went down the toilet, and I frantically started looking online for a replacement timing belt. No nearby Euro Car Parts had it in stock or were closed, but luckily a small local motor spares place happened to answer the phone and after some back and forth about engine type and number of teeth, he had the belt I needed in stock! :worship: (XL Motor Spares New Malden)
But that was the easy bit. I knew from doing this last time that changing the timing belt (on my car at least) is an absolute ball-ache. The first obstacle of which was getting the Punto up off the gravel driveway onto the concrete so I could jack it up. Luckily the (not so) redundant Fiesta was sitting behind it, so I roped in mum to gently reverse into the Punto and push it up the drive while I steered.
(to protect both cars lol)
With a bit more shoving I got the Punto on the hard-standing and got back to work, removing the alternator belt pulley from crankshaft pulley being my biggest struggle.
As you can see 1 of the bolts is especially rounded off (the other 2 partially) due to the fact that its very tough to get a 13mm spanner on the central nut, and a 13mm socket on the outside ones. I eventually got that last one off by hammering on a slightly smaller imperial socket, and have since 're-sized' it with a dremel to square off the edges.
Anyway, after loosening the alternator (also not fun) and removing that belt, I had access to the crank pulley and could finally remove the timing belt. Gave it a clean all around as there was a fair bit of oil and shredded belt everywhere (with the consistency of sheeps wool!) and put the new belt on. Lined up timing marks as best I could and tensioned the belt, was going to start it up without the alternator pulley or belt attached just to check, but thought against it.
With everything reinstalled, it fired back up and ran OK...... the actual valvetrain sounded a lot smoother with less 'tapping', but the idle was quite rough and there was a new noise coming from the timing belt side of the engine - kind of like a whirring/grinding noise. let it run for a bit and after looking and listening through a long screwdriver I couldn't find anything disastrously wrong.
After dinner that evening I decided to go back and set the belt tensioner slightly less tight, as I thought that might be why the previous belt was worn so badly after only a couple of thousand miles. I experimented with very tight/very loose (which produced the typical whining noise), and got it to a point I thought was best. The idle was still very rough at this stage so I played around with the timing after some googling, but haven't been able to get it to smooth out.
So anyway that's my story from the weekend. I had to get back to Maidstone from South London that night so nursed the Punto back ~50 miles, idle didn't smooth out, but noises didn't got worse either!
I'm thinking the new noise might be the alternator or its belt needing adjusting. Timing wise I'm going to get hold of a small mirror to check the markings through the bell housing, as I think I might just be a tooth or 2 out.
Any comments/help/guidance would be appreciated. The struggle continues!
(god I hate these dark winter evenings)
