Thread Tools
Old 10-10-2014   #31
kazer92 has donated!
not a bad shout blu, will give that a go before resorting to extreme measures.
Reminded me of a Simpsons scene haha
"That's not a knife, this is a knife!"
"That's a spoon"
"Ahh, I see you've played knifey-spooney before then"
Thanks SB1500 thanked for this post
kazer92 is offline Reply With Quote Quote
Old 27-10-2014   #32
Re: my 200 '95 Mk1 75sx 'Paddy Punto'
been plodding along with this over the last few weekends, delayed a bit waiting for a valve spring compressor of ebay, the ones in halfrauds were 50 quid! one i picked up was 27.
at first i thought the compressor was the wrong size, took a bit of brute force but got all springs compressed eventually and got the valves out, with all the little bits kept together in sandwich bags. cleaned the valves up using a combo of a screwdriver, rusty nail, and emery cloth whilst spinning the valve in a powerdrill, wedged between my legs/table. heard of this trick while preparing for the task, worked a treat!
once i got the valve stuff out i could see that one of the valve stem oil seals was perished, which could explain the residue in the ports. new gasket set arrived with head bolts (and oil seals), and new water pump is on its way.
next job is to lap/grind the valves into thier seat with the suction stick + paste stuff i'd picked up previously
have decided that I will get the cylinder head skimmed just to be on the safe side, won't be for another few weeks as I'm away at the weekend.
weathers getting colder now, luckily doing most of this work in the shed at the moment but not looking forward to putting the engine back tother on the driveway with freezing hands!
Old 17-11-2014   #33
been fairly productive since last post, lapped the valves into thier seats with the fine grinding compound since they weren't in too bad shape.
got the cylinder head refaced/skimmed for 30 at a engineering shop near Epsom, dropped it in one evening after work, was ready to pick up same time the next day, friendly fella as well!
after finally getting this done i've got no excuses not to be cracking on with putting everything back together. put in the new oil stem seals with a bit of convincing with a hammer, then in went the valves, springs etc. fairly easily after i got the hang of it.
have also got the camshaft back on the other side of the head, had to redo that after finding out that you need to position the shaft so the no.1 cylinder lobes are pointing upwards in a V shape, meaning TDC. (hope this is right)
next job is cleaning up the engine block surface before fitting the new head gasket and putting the head back on. if the weather is on my side i could probably get everything reassembled in one weekend, although doubt that'll happen haha, especially as I didnt really label any components when removing them
Likes FrederikN liked this post
Old 01-09-2015   #34
Thread resurrection
wow it's been a while, and the Punto's been off the road nearly 10 months. time for a shameful thread resurrection.
Unfortunately I moved away from home to a place nearer to work, with no space to store another car and not many free weekends to pop back and work on it. The Punto has been looking very sorry for itself at the end of the driveway, gathering cobwebs and moss, tires deflating, as I drive my boring Fiesta as a daily.
Have no fear however! I was home at the weekend after deciding to get my arse in gear. I didn't have time to take any photos, but summary of progress so far.
- i put the resurfaced cylinder head back on without cleaning up the block. didn't torque the bolts so was able to remove it again and do it properly with fine sandpaper and a woodblock.
- before this i had been trying to ignore a nasty problem - thermostat housing bolt hole in the head had stripped and would lead to a massive leak. ordered an M6 helicoil kit and eventually got that done after nearly ruining the hole completely (drilled out hole, re-tapped, screw in coil etc.) thread now stronger than ever.
- so cylinder head and manifolds are now back on the car and attached, just need to torque the head bolts.
- next job is timing belt. I have a new belt and tensioner, but not sure if i'll be able/bothered to remove the old one, as it requires removing the alternator pulley and such.
- also worried how i'm gonna sort the timing. i left the engine cranked at TDC cylinder 1 (I hope), and the camshaft in a V which should hopefully match. the car is on gravel so can't jack it up to access the crank pulley timings marks. would love to know another method of setting up the timing.
other than that, i'm confident i could get the car back on the road in another day or 2, its just finding those spare days!
the main reason i stopped work in the first place was due to the winter weather last year, need to get this done before it comes round again!
if anyone's out there, I hope some of this is somewhat enjoyable haha
Likes SB1500, X1S1 liked this post
'96 Fiat Punto Mk1 75sx - Scrappage Scheme Survivor & Daily Driver!
'98 Ford Fiesta Zetec GL - Boring Backup (SORN)
"A man with a fork in a world of soup" - Noel Gallagher on Liam Gallagher
Old 02-11-2015   #35
simon_16vpunto has donated!
I find this enjoyable as I too have a punto 75 I'm restoring
Likes X1S1 liked this post
simon_16vpunto is offline Reply With Quote Quote
Old 09-11-2015   #36
the car runs! done a fair bit since last post on this thread, started a new one to figure out a idle hunting/surging problem, have a look here:
http://www.fiatforum.com/punto/43112...g-hunting.html
so I replaced the timing belt after initially getting the wrong one, getting the crankshaft pulley off was a bit of a nightmare as well which took some chin-scratching, timing now all ok, and fixed the engine trouble through the above thread. It still has quite a high idle, but i plan to patch up some vacuum leaks at some point and the ECU will also need a while to re-learn etc.
I took it out for a spin to the local Tesco for petrol and a dual carriageway stint (no MOT, tax or insurance but needed to do it). ran fairly well, although i'd completely forgotten what the car feels like, steering and gear shifting feels weird, and the lowered springs are still as bouncey as they were....... nothing like my boring Ford Fiesta daily, which in fairness is a lot more comfortable, quieter etc. haha
it's been a long journey up to this point, i've learnt so much and couldn't have done it without this forum. I now find myself at a crossroads however....
Plan is to bring the punto to our family friend/mechanic to look over and see if he could get it through an MOT. some new floor pans and rust were marked as advisory on the last MOT about 2 years ago, so lots of welding may be required, which I couldn't do myself realistically.
So at that point i'll have 2 possibilities, either the car passes the MOT, i keep it and start to drive it daily again. I need a fairly reliable car for work so not 100% sure on this.
Or my beloved punto needs too much work to get through an MOT. at this point i'm not sure what I'd do, break it a try to make some money back on parts? (takes time and effort), sell it as spares? or scrap?
I definitely don't want to be thinking about this, but it has to be done. I also have been thinking I need an upgrade anyway, and have been looking at Mk2 Golf GTI's, but that's another matter.
I'm also aware that this car is getting on a bit, fairly rare these days and potentially a classic (lol)
any advice would be appreciated!
Likes SB1500, Sir16v liked this post
Old 09-11-2015   #37
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Snowboard Slalom Champion, Skate Boarder Champion
well first thing to do is have a look for rust and give any bits you find a good poke with a screwdriver to see if they are bad or superficial - welding takes time and its the labour that costs alot so unless you can get mates rates somewhere that can end up costing alot - plus you really want a decent job doing and not just crappy patches here and there..
Ultimately we can't tell you what to do here, you have to decide... But i really would get under it and check the sills, pull the carpet up and assess the floor, same in the boot and around the rear arches. If its bad then its prob not financially sensible to repair, you could try find a decent shell and convert it to 75 stuff, you could just throw in the towel and scrap it, you could break it for spares (75 parts are getting rare and sure you could sell quite alot of it pretty easily). Which all brings me back to only you can decide - but first things first, assess where the shell is - ask this family friend mechanic dude if he can stick it on his lift and have a poke around, try be there to witness so if he says its the end you can agree without a doubt is what i would do.
Charmander - Panda Mania 1242 mpi 8v - thread
Unnamed - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT
blu73 is offline Reply With Quote Quote
Old 09-11-2015   #38
wise words thanks very much, i recently acquired some car ramps so along with my jack stands I can have a good look at the underbody. I've noticed a fair bit of surface rust whilst working on it over the years but not had a proper look. my main concern would be jacking points maybe; I don't use these anymore in case I squash them, now jack up from the ARB or wishbone mounts. wheel wells look fairly clean from what i remember.
if i had more time and the car was based where I currently live, I had always planned to invest the time and money to buy a welder and learn, but no can do at the moment.
We'll see how it goes anyway, will update on any progress
Old 16-11-2015   #39
not sure if anyone's seen the other thread I had on the dodgy idle, but it's all fixed now, thread can be found here:
Old 17-11-2015   #40
forgot a few other photos from the weekend, got the Punto out from behind the house and just gave it a blitz with the pressure washer to remove over a year's worth of grime/mould.
and the low-hanging speed-bump basher:
If i remember correctly it's just a generic exhaust thrown together when the muffler blew on the old one. I tried using cable ties a while back to 'tighten' the rubber hangers, which only helped a little. I plan to take the rear lowered springs off anyway and put the original ones back on before the MOT, it looks good parked on a flat drive, but over bumps or with any people in the back, I remember it being an absolute nightmare of metal-on-concrete action....
Old 20-11-2015   #41
Sweden
Looks good ��
Dansken is offline Reply With Quote Quote
Old 15-12-2015   #42
cheeky update before everything gets manic for Christmas, had a good few hours spent under the Punto at the weekend and got a fair bit done.
Pic beforehand. sorry there won't be many photos, was racing the daylight all day!
First job was changing out rear springs, car sits far too low at the back to be practical, and is was bumpy as hell on motorways I remember.
wire brushed the stock springs and gave them a quick coat of black spray paint just to tidy them up a bit, there was a fair bit of rust
lowered springs were fairly easy to get out, but the taller stock ones were a bloody nightmare to get back in, managed it eventually with a crow bar and a good kicking!
Next job was a cooling system flush, as it still had just water in it since I replaced the head gasket and i thought it needed a good clean. bought a bottle of Wynne's radiator flush and let it run for a while, let it cool and then drained into a washing up basin (sorry mum)......
yeah I'd say that's better out than in.....
flushed once more with just water in the system then filled it up with blue readymix coolant, bled and tested the air blower for hot air, all good and ready to roll!
also discovered a perished rear exhaust hanger that was only just holding up the back box, replaced with a generic rubber mount and reinforced with a hose clamp that will hopefully hold for a while.
got some replacement rear licence plate bulbs to fit, and some niggling brakelight wiring trouble to fix and then MOT time i think. Hopefully not long into the new year
Likes blu73 liked this post
Old 15-12-2015   #43
flisko's Avatar
flisko has donated!
antifreeze looks yummy
Likes SB1500 liked this post
flisko is offline Reply With Quote Quote
Old 15-12-2015   #44
It's great to see a mk1 that's loved. Fingers crossed you're able to keep it going for several more years! Sadly, a lot of mk1 Puntos are being used as engine donors by classic Panda enthusiasts.
puntofan01 is offline Reply With Quote Quote
Old 15-12-2015   #45
flisko's Avatar
flisko has donated!
Quote Originally Posted by puntofan01 View Post
those bastards
Thread Tools
(Tu) Fiat Punto MK1 75SX Exhaust. adrianbon Punto (Mk1) 5 03-10-2010 19:47
Punto (Mk1) My punto mk1 75SX Madpunto Members Motors 16 07-08-2009 20:01
(G) punto mk1 75sx problems dazzercox Punto (Mk1) 0 09-02-2009 18:14
(T) Punto 75SX -95(mk1) cutting out. joel Punto (Mk1) 2 25-07-2005 13:04
50 for a Mk1 Punto 75SX, with alloys? JonnyBoy Leisure Lounge 10 10-02-2005 18:28
