- Oct 13, 2009
- 423
- 148
After 19 years and 100,000 miles of total reliability, our 1994 1.6 Cabrio has developed a problem. It has always started instantly, but just recently it has developed an intermittent fault. It started with hesitation after a couple of minutes driving and the engine management light coming on. Switching off the engine and restarting it would clear the problem. This then developed to the engine cutting out completely, but restarting ok, only to stop again soon after, regardless of the engine revs. After a few minutes of this behaviour it would be ok.
Today, we moved to the next level. After about six miles of driving, I was travelling at 70mph on the A14 when it first hesitated, then cut out completely. It would not restart and I flattened the battery. A passing friend with a booster stopped, but still the engine would not fire, so I called the RAC. Two and a half hours later, the RAC guy turned up, attached his booster and the engine fired instantly. He followed me home, but the engine didn't miss a beat.
At first I suspected the fuel pump, as I have had one of those fail on my Jag, but that never failed while the engine was running, only after the engine had been stopped. My next thought is the crank sensor, but before I start replacing bits, I thought I would see if anyone here has had the same experience.
