- Jan 20, 2013
- 6,151
- 1,228
I think is OK what you see. The crankshaft rotates twice as fast as the camshaft. So 180 is OK, as another crankshaft rotation will result in the camshaft go to 0 degrees, i.e. aligned. If you get it very wrong as you feared the car will not run at all. One teeth or two off alignment can cause some running issues any more probably will cause bad running.
what kind of running issues? stuttering looking like maybe?
