weewillywinky
i have recently aquired a mk1 fiat punto and quite often, as i raise the revs a bit to pull away, the engine just splutters and will try to cut out, or if it happens as i am going along (normally when ive changed up a gear) and i push on the accelerator pedal a bit more it will spurt forwards after doing this for a couple of seconds and then just carry on as normal again. It just seems to randomly do it as some days it will be fine. Why is this????????? Has anybody else suffered anything similar???
