they aint hard just boring find a guide, as long as seats aint damaged ive got some valves i think
Been doing a little research and ordered 8 exhaust valves.. All the inlet ones look good.
Been watching some vids on youtube and it looks very easy tbh. Need to get a spring compressor but not sure what to get. Most of the vids I've seen use a compressor that clamp on to the top of the spring and cap. The majority of stuff on ebay are like a G clamp which press on the top of the spring and the the bottom of the valve.
Would prefer the clamp on type but space may be limited? Looks quite tight on some of the valves.
Looking at some of the g-clamp types, im not sure some will work properly, so any recomendations?
Ones the spring is compressed, the vids mosly show people removing the the retainers with a magnet. Is this the same on the fiat engine or do I need to pop them off another way?
Then is it just as simple as swapping in the new valve and get the spring back on? The head gasket set I got came with the valve seals so I may as well replace. Do they just pop on and off?
