The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
FIAT Auto Specialist Team
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 10-07-2008   #16
Sally
Captain Mike's Avatar
Captain Mike has donated!
Re: mk2 punto wiper linkage upgrade. from £30.20
yeah my dad was making plans to drill the wipers and i stopped him.
Just buy the linkage or live with one wiper
EDIT: whilst we are on about wipers mine are crap (i think its the wiper blades) they make annoying noises judder (i have seen the guide and will give that a go one day).
but what wipers do people recommend?
Captain Mike is offline
Old 10-07-2008   #17
My Sweet Shadow
ChrisUK's Avatar
ChrisUK has donated!
Bartender Champion
Bosch Aero (the ones with the build in blade spoiler). Very smooth
Present: 05 Punto Sporting 1.4 16v & R Plate Fiat Coupe 20VT
ChrisUK is offline
Old 10-07-2008   #18
Super Moderator
dave's Avatar
Trader Rating: 10
dave has donated!
dave doesn't view adverts
Saint Kitts and Nevis
didnt you get new set of wipers with the linkage?
Binki
Rip binki
dave is online now
Old 11-07-2008   #19
Sally
no
i couldnt be arsed to complain but i might now
Old 17-07-2008   #20
jiohnnyp has donated!
Hi All,
I look after a couple of Mk 2 Puntos, linkages arnt too bad, spindles/housing are REALLY!! loose and floppy.
Dose anyone supply spindles?
Hav'nt been in for while, still GREAT site.
THANKS
jiohnnyp
jiohnnyp is offline
Old 17-07-2008   #21
Super Moderator
dave's Avatar
Trader Rating: 10
dave has donated!
the top kit comes with new spindles
Binki
Rip binki
dave is online now
Old 14-08-2008   #22
hey guys im new to this website and my window wipers keep popping off and is really starting to do me nut in. i do a quite a bit of motorway driving at night and in the rain typical england lol so i need a permanent fix for it and am a bit unsure as to which one to go for either the 30.20 one or the £65.00 one any help appreciated
jason88 is offline
Old 14-08-2008   #23
Super Moderator
dave's Avatar
Trader Rating: 10
dave has donated!
both are permanent, the 30 quid kit is easier to fit
Binki
Rip binki
dave is online now
Old 22-08-2008   #24
The connection on my wiper linkage broke on my Fiat Stilo 02reg. Will this £30 linkage for Puntos fit a Stilo too?
andrew_shoe is offline
Old 22-08-2008   #25
Super Moderator
dave's Avatar
Trader Rating: 10
dave has donated!
dont think so
Binki
Rip binki
dave is online now
Old 25-08-2008   #26
does anyone know about a replacement wiper linkage for a stilo? I've scoured the net and can't seem to find anything for it particularly and don't want to shell out the hundred odd quid that I'm sure fiat will charge me for it!!
any clues...?
the joint was fixed by the rac after it jammed up to stop the driver's side wiper working in heavy rain. but it's only a matter of time I reckon till this goes again...........
Old 28-08-2008   #27
Well quite a good idea by the looks of it... as the arms are quite pants, mine popped off the other week when the heavy rain was on.. well the wiper blade fell apart lol.. and for some reason.. it jammed and the arm fell off.. they are a pain to pop back in unless you've got the wipers half way up the window while doin so.
Fix-It-Another-Day is offline
Old 02-09-2008   #28
BYE BYE PUNTO..HELLO BMW!
Trader Rating: 3
Harj has donated!
Dave, top man!
Just fitted these today to my wife's Punto Mk2 JTD. Ordered the Wipex Push Rod from ebay for £30.50.
Bloody top tip!! Thanks a lot. Wipers are Brill !
R.I.P PUNTO.... HELLO BMW !!
___
Harj is offline
Old 03-09-2008   #29
If you have a Mig welder it is easy enough to do something like the upgrade by modifying the existing bits. You can buy little balljoints with a threaded socket like on a trackrod end. You cut off the old ring/socket bit and weld on a 6mm bolt into the pressed steel channel. The ball end of the old joint can be knocked out with a punch and replaced by an arrangement of bolt, nuts and washers to fix it to the ball part of the new joint. For the double joint you can just weld a washer on the end to stop the arm from coming off or you can use 2 of the balljoints described above. You need to measure the distance between centres of the original joints as accurately as possible so you can adjust the new setup the same.
http://www.fiatforum.com/doblo/13800...ml#post1449122
Start each day with a smile and get it over with.
fido is offline
Old 05-09-2008   #30
I had the same problem with the passenger side wiper blade always falling off so instead of payin £££ for a new linkage arm i got a small jubalie clip and tightend it to the underneath of the arm on the wiper now it wont fall off but after reading the posts on here i might actually start to look into it and maybe buy a new set from Wipex as my wipers seem to judder alot!
JBMF90 is offline
The following user says "Thank You!" to JBMF90 for this useful post:
Haimer (06-09-2008)
Tags
wiper, punto, linkage
(T) Wipex mk2 wiper linkage upgrade Puntoboy Punto 14 03-03-2007 18:59
(T) MK2 Punto wiper linkage, with motor or not? 01punto_funkybro Punto 0 25-01-2007 15:58
punto mk2 wiper linkage dave Auction Watch 0 13-11-2006 18:19
(T) mk2 punto wiper linkage upgrade its in! hailesy Punto 0 01-09-2006 20:59
Copyright ©2002 - 2010 FIAT Forum
