casement60sx
hello over these past few months i have noticed that there is a banging noise coming from my back end everytime i hit a speed bump or any sized pothole in the road has anyone else had this and if so what was it reply asap
cheers lads for the ones that replied with a reasonable answer my local mechanic i use said it could be the rear arms
Strangely my car seem to suffer similar problem. N/S rear seems to make more noise then I expect over bumps and rough surface. No handling issues yet so a bit puzzled. How do we test the rear arms?cheers lads for the ones that replied with a reasonable answer my local mechanic i use said it could be the rear arms
as allready said above, put it on a ramp/pit and check for movement with a bar.Strangely my car seem to suffer similar problem. N/S rear seems to make more noise then I expect over bumps and rough surface. No handling issues yet so a bit puzzled. How do we test the rear arms?
My money is on trailing arm bushes u can just get a repair kit from eBay 10 pound a side and u may aswell do both at the same time
