Hi there, have had a browse of old threads re overheating puntos but wondered if anyone had anything to add. My situ is this:-
- 1998 punto, reasonable mileage owned nearly 2 years.
- Had new head gasket in May 2010 as overheating constantly. Fine after this.
- Had new battery last week due to cold and while it was in the garage. Aldo putin a smallbottle ofcoolant into the tank.
- Prior to this the light on the dash (the red one near the petrol indicator) had been coming on during quite short journeys.
- I thought it was just low coolant but even after refilling it is still coming on during short trips.
- Heater only blowing cold air. To be honest haven't specifically checked for leaks but not noticed any puddles etc like before HG repaired.
My question is this - do I add more coolant (as onlysmall bottle added) or is it something dreadful which is going to require more cash? I've also seen this K Seal / Radweld stuff - is that worth a go? This car is ideally going in the Summer when I buysomething newer so only needs to last until then.
Any help, opinions and advice welcomed!
V
first... radweld/k seal... works "Sometimes"
but it is ill advised.. might fix the problem, but can clog up heater matrix's and car radiators or at least reduce the efficiency of them.
you put a small bottle of coolant in?
if it didnt have antifreeze coolant in it, that is not the proper way.. proper way is
- to drain by removal of bottom hose normally,
- flush (with cold engine) backflush with clean water until water runs clear
- put hoses back,
- look up antifreeze quantity
- if it says 4 litres.. because it is 50/50 you put 2 litres of neat antifreeze into the engine which is 50% of the total coolant required,
- then top up with water until full... preferably distilled, as distilled has many advantages over tap water.. but tap water wont harm the engine... long term it can cause heater matrix and radiator clogging over a period of years... which is why distilled is always recomended as it can prevent that...especialy if you live in a hard water area.. only have to look at what tap water does to your kettle.. it will do that to the inside of your radiator and heater matrix as well.. distilled water wont.
Reason you dont mix antifreeze and water first in a bucket or something then put in, is because..it doesnt account for any plain water left in the heater matrix and bottom end of the engine which will weaken the overall antifreeze strength... so by putting the 50% antifreeze in first, you will always have the correct amoutn of antifreeze in the engine. Then just top up with water.
then you bleed any trapped air out of the heater hose on the back of the engine, right hand side.. and top of the radiator right hand side.
some MK2B dont have the bleed point on the heater hose located on the rear of the engine right hand side.. as it has a hose instead that goes back to the radiator to automatically bleed... but radiator still requires bleeding.
In your case, because the heater is not getting hot and remaining cold first of all, try bleeding the system to get any air out as an airlock can cause overheating.. and it sounds like trapped air.
If there is no air in the system, and it still overheats could be the thermostat stuck closed.. after bleeding once your sure theres no more air in the system.. check the top radiator hose, right hand side gets hot when the engine warms up, if it does thermostat "should" be working, if it remains warm or cold, thermostat is no good which is whats causing the overheat, as it wouldnt be allowing the coolant through the radiator to cool it down.
But im leaning more in the direction of air in the system at the moment because your heater is not getting hot, rather remaining cold.
In which case.. DO NOT run the engine too much with air in the system, as it can blow the head gasket again... if it hasnt already.
If the head gasket has blown again, I would persue it under warranty.. should have 12 months or 12k miles at least if it was done by a Garage.. if its not, then trading standards willl be interested... and if it has blown again, which im sorry to say sounds like it may of, it was not properly repaired back in may.. was the head skimmed?
Reason why I think that is because from what I can gather.. it was overheating, you put a bottle of coolant in, because it was low? which would of caused the trapped air...well it should not of lost the coolant in the first place, and it was that loss of coolant that started the chain of events
Lost coolant --> overheating --> Trapped Air --> topped up --> trapped air still present which is why its still overheating.
If it did not loose its coolant to begin with, it would not of got trapped air, you would not of had to top it up etc.
my car, had since 11 months old.. 3 years old nearly now and ive only topped up with a very small amount 1ce just this week.
Then, keep an eye on the coolant levels, if they are dropping or staying the same.. under normal circumstances.. should not loose ANY coolant from an engine, as theres nowhere for it to go... being its a sealed system.
