I own Grande Punto 1.2 Emotional model since Sep 2010.
I am facing brake failure issue
This issue occurs only in low RPM like when you are bring your car from parking where you need to apply 1st and reverse gear couple of times.
or when you are driving in slomly moving traffic where you can't release clutch fully (even in 1st gear) and you need to keep your feet on brake padel to avoid bang into next car. If you face this situation for around 25-30 seconds you will find brake padel very hard anbd brake is failed. You need to press clutch fully in order to get vacuum recreated in brake booster. If you are running on AC , then vaccum takes 5-6 seconds otherwise it takes 2-3 seconds.
Please let me what to do?
