I've had this squeak ever since I had the car.
When I'm driving it sounds like there is a rubbery-type squeak coming from the nearside rear of the car. It's quite loud and I think it's coming from inside the car, like its the parcel shelf or something moving the window rubber. I've checked this though and I do not think it is this.
It is quite rapid, and is related to the road surface conditions; rough surface is constant squeak-squeak-squeak constantly, on tarmac it squeaks when changing speed/gear or bumps etc.
These symptoms lead me to believe it is something to do with the suspension system. I had an MOT advisory for soft shock absorbers; they are very soft compared to the front and body roll is excessive imo. Could this be the cause? Not the shocks directly per se, but the spring mountings could be squeaking due to taking more dynamic loading than they should?
Oh yeah and sound appears to be better with people in the back. Although the sounds occasionally won't be there for a journey or two then will be back again so I don't know for sure.
It's obviously hard for me to fault find this when driving along so some guesses will be fine even if you aren't sure. I'm just not sure what to try first. I was going to change the shocks anyway for the next MOT so I might do that.
Cheers for replies.
Cheers for replies.
