hello,
problem 1.
i have a 1994 M reg punto 55s
the ECU light was showing intermittently (usually whilst idling at traffic lights and coming right off the accellerator pedal) tried the ecu reset, which hasnt worked, light still comes on, when the light does come on the engine sounds different, and iff at speed with little or no gas, its almost as if ive tapped the brake pedal, question 1 is...whats causing it?
The air filter box clip is broken....it tightens but i would imagine the seal is not air tight, could this be causing it?
problem 2.
the mpg seems really bad,there was just under half a tank yesterday(around 13/32nd of a tank, and after about 7-8 miles im on a quarter. what could cause this? and could the two problems be related
any help greatly appreciated
a hunch of mine is the spark plug gap?
im gonna try a "temporary fix" on the air filter (old work belt) in the air filter until i can fine one in a scrappys(none today when i went,only 3 puntos in total) and see if that cure any one of the two problems
problem 1.
problem 2.
