davethedrummer
I believe way back in August last year I graced you all with a little cam belt tensioner issue. Well...... I think the little Punto has felt left out and decided to spring a new problem. It's leaking water, from somewhere around the thermostat casing (as you look at the engine from the front of the car, top right of the engine block, just below rockerbox casing). Any ideas what this could be? I don't have any record of the radiator ever being changed, nor water pump, nor stat, so it makes sense for something to go wrong. Only started noticing it because the heaters occasionally don't work, and the car starts to overheat. This is probably just because the coolant level is a little low as it keeps leaking. Any ideas? I'm going to have a play now, I'm hoping it's just a gasket. It's been doing it increasingly over time so that'd make sense. Either that, or a blockage. I don't think it's water pump as the leak wouldn't make sense.
Cheers for the help (in advance!)
Dave
Dave
