Our Mk 1 Punto (85 16V) failed the MoT on emissions. As I have just replaced the head gasket and it is running well our conclusion is that it must be the lambda or the cat. I have a 75 sx for spares (none of which usually fit - so if anyone needs a part let me know) so I have swapped over the complete exhaust with cat - the cat is a different part number and it just as easy to fit the whole lot.
My questions relate to the lambda sensor. Is there any real difference between the lambda sensor fitted to the 85 compared with the 75 other than the length of the lead?
If I fit the one from the 75 should I leave the longer length lead intact or should I cut it to the same length as the original?
I don't mind paying the £70 for a new lambda sensor if I have to, but I would be happier "recycling" the one from the 75.
David
David
