The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Firela Motors - Your South London FIAT Specialist
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 4 Weeks Ago   #1
Xmas-Boarding Champion, Beer Addict Champion, Ghost Hunter Champion, Mario Catcher Champion
Rear Shoes
Hi Guys/Girls,
I have a Punto mk1 97 1.2, The thing is i need to change the rear shoes on her Anybody know the size of the socket i need to take the bolt out of the drum.
Many thanks.
PUNTO SX 97 1.2
MODS:Clear Side Repeaters/Smoothed Sides/Janspeed Exhaust
NEEDS:Lowering/Bodykit/Debadged
Dont Forget to Thank Me
MyPunto
unimatrix1 is offline
Old 4 Weeks Ago   #2
MikeSalt has donated!
Re: Rear Shoes
Do you mean the small bolts with the spikes, or the mahoosive bolt in the middle? If the latter, then that doesn't need to come off to remove the drum, you just unscrew the spikes, release the handbrake and the drum should pull off.
If it is stuck on there, the drum is actually threaded where the spikes were to help you. Bolt long bolts only partially in, and use these to pull the drum off.
MikeSalt is offline
Old 4 Weeks Ago   #3
Wink Re: Rear Shoes
Rite so i dont need to remove the big massive nut in the middle of the drum to change the shoes i just need to remove the 2 spike things?
well i removed 1 of the spike things today with a spanner come to undo the other one and it rounded it a bit so now i cant seem to get it to budge any help on this would be much appreciated many thanks for the previous advice.
PUNTO SX 97 1.2
MyPunto
Old 4 Weeks Ago   #4
Re: Rear Shoes
Precisely, take the drum off and you can then take the shoes off. The big nut in the middle is the hub nut, which holds the hub/bearing assembly on, so not necessary to remove for this job.
As for your spike nut, these are tricky little buggers to get out once rounded. First soak in WD-40 or other alternative penetrating lubricant overnight. Try to use a 12-point closed spanner rather than an open spanner. If that fails, get a deep socket that is slightly too long and hammer it onto the spike, using a breaker bar to undo it.
MikeSalt is offline
The following user says "Thank You!" to MikeSalt for this useful post:
unimatrix1 (4 Weeks Ago)
Old 4 Weeks Ago   #5
Super Moderator
dave's Avatar
Trader Rating: 10
dave has donated!
dave doesn't view adverts
Saint Kitts and Nevis
Re: Rear Shoes
jobs a whole lot easier if you remove the hub, i always do, 32mm
locating spikes i use mole grips if spanner bit is buggered
Binki
Rip binki
dave is online now
The following user says "Thank You!" to dave for this useful post:
Old 4 Weeks Ago   #6
Re: Rear Shoes
Dave, does the inner ballrace ever get stuck to the stub axle when you pull it off? That's a £40 jobby if it does.
MikeSalt is offline
Old 4 Weeks Ago   #7
Super Moderator
dave's Avatar
Trader Rating: 10
dave has donated!
Re: Rear Shoes
no normally if hubs knackerd it all falls to bits. new hub for non abs can be got for £25 at motorfactors
Binki
Rip binki
dave is online now
Old 4 Weeks Ago   #8
Re: Rear Shoes
Both very useful advice. I shall have another go at it on Wednesday when i have some money to buy a decent set of mole grips Thanks for the advice.
Also i have rang around for the rear drum shoes for my vehicle and got told that they have 2 sets for it ones that come with adjusters and ones that dont.. do you guys know if mine will have the adjusters or not ?
PUNTO SX 97 1.2
MyPunto
Old 4 Weeks Ago   #9
Super Moderator
dave's Avatar
Trader Rating: 10
dave has donated!
Re: Rear Shoes
should have adjusters built on, but its always an idea to take old shoes with you when you go get new
Binki
Rip binki
dave is online now
Copyright ©2002 - 2010 FIAT Forum
