The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 09-02-2010   #16
Re: cambelt change
my punto 1.2 16v belt + tensioner was £30 to buy but that's a Mk1 model.
Garage i'd imagine would be around £250 mark.
And on the belt there are theories between 36k and 72k but imo it depends on your driving. If your doing lots of short runs then i'd go shorter but at 42k unless it's more than 6 years old i wouldn't worry too much about it yet.
Oh and when i did mine i messed the timing up and had fumes coming out the airbox, engine out by 180 degrees on the bottom end. And if the Mk1 engine is similar to the Mk2 engine the "special tool" is a 10mm allen key.
Mk1 Punto Sporting 1.2 16v in Black with marked wing and electric sunroof motor bust.
thefallenangel is offline
Old 09-02-2010   #17
Re: cambelt change
it's a 02 plate with nearly 43k so I think I will have it done anyway, going to have water pump done too. Not doing myself one of those things I wouldn't want to attempt, leaving it to a garage lol
I know someone has mentioned 3hours labour is that about the average a garage would recommend
Punto MK2 sporting 6speed
OMP racing back box, GSR induction kit, Carzone rear bumper, Abarth Front Bumper & Side skirts, Spoiler, handbrake handle, gear surround and pedals, colour coded mirrors & handles, TOYO T1R's, K1 10mm HT Leads, OMP fronts & Bilstein rears, Eibach pro kit .
mahol is offline
Old 09-02-2010   #18
Re: cambelt change
got timing belt kit and water pump for £71 and have a quote of £138 to have them fitted tomorrow. The quote including parts was £238, but i sourced the parts cheaper worked out even cheaper than shop4parts too.
the Timing belt kit is made by Dayco and the Water pump is QH.
mahol is offline
Old 09-02-2010   #19
turboo
beau's Avatar
Trader Rating: 16
beau has donated!
Re: cambelt change
dont seem to bad, just make sure they have the timing tools if they do it without then that price is very expensive cos it wont take more than an hour and would be 'slightly' out of time.
1985 fiat uno turbo
1997 fiat punto sporting 16v
2003 bmw 330ci
beau is online now
Old 09-02-2010   #20
Re: cambelt change
timing tools cost pennies to make for the Mk1 so if it's similar to Mk2 (3 lengths of bar (bottom end) and a 10mm allen key (top end) then £138 for 3 hours labour is about right as it took me 2 hours to do so including paper work + test run then 3 will be better.
Old 09-02-2010   #21
Super Moderator
dave's Avatar
Trader Rating: 10
dave has donated!
dave doesn't view adverts
Saint Kitts and Nevis
Re: cambelt change
10mm alan key can still move enough to mess stuff up, its only £21.52 for a pair of lockers, an you only need 1 so can sell the other
Binki
Rip binki
dave is offline
(T) 2.0 20v cambelt change help and fuel filter change help Wilqaeda Marea 4 13-10-2009 12:20
(T) cambelt change tango2007 Punto 1 28-06-2009 16:27
(T) Cambelt change injector Ducato 8 31-03-2009 21:06
Cambelt Change doblo Doblo 9 18-09-2006 16:26
(T) Cambelt Change Muttley Stilo 6 16-11-2005 10:36
Copyright ©2002 - 2010 FIAT Forum
