The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 06-02-2010   #16
Re: Car battery Dead
just checked voltage and its on 12.55v so it doesnt look likes it getting drained.
Could possibly be the alarm system. altho when it was doing this before i dissconnected the alarm and got similar issues
Tony123 is offline
Old 06-02-2010   #17
Originally Posted by bredsticz View Post
Faulty starters have been known to drain alot of power, not sure how to test though, sorry
ive had a feeling i could have a faulty starter.. cause ive had problems starting it sometimes..
Like if i turn engine over it will act like theres no power, but then it will always start straight away from jump start.
Tony123 is offline
Old 06-02-2010   #18
Bugs Beware!!
Spentona has donated!
Add Like Mad Champion, Badger Race Champion, Bumper Golf Champion, Smaugs Treasure Champion, Valentine Surprizes Champion
Normally if the altanator is failing then the alternator light stays on when the key is removed (but not always)
If the battery is going flat overnight when connected then try removing the fuses half at a time,if it doesnt go flat then it something in that half. If it goes flat then put the first lot back and remove the other half, if it still goes flat then start looking at other items, i.e. disconnect the starter lead.
WHEN GOD SAID SIX PACKS I THOUGHT HE MEANT BEER, SO I ASKED FOR A KEG
THE ONLY THING I CAN SEE MY TAXES BEING SPENT ON IS MORE WAYS TO TAX ME
Spentona is offline
Old 07-02-2010   #19
A battery can show 12.5V but have some cells with next to no charge capacity. If it spins over OK on jump leads then its not the starter and most likely to be the battery.
WhiteSei is offline
Old 07-02-2010   #20
Once you go Burple
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
Remove, clean, abrade, refit very tightly, the grease all ends of all engine bay earths.
SPD
Marriage sounds like a grand idea.
Divorce is more like a hundred grand
rallycinq is offline
Old 08-02-2010   #21
i did the test to check if it was a faulty earth and still same effect.
I drove about 100miles yesterday after jump starting so its had a nice little charge.
This morning i unplugged my heater motor and it started up fine so atm its going ok
I thought it could bt the heater motor because the wire is just under the glove box and people may have caught it with there feet.. and the other day i went to start my car and there was hardly any power (very dim dash lights). I put car into first to roll start it, but then thought there wasnt enough power to do it. As i took it out of first gear all of a sudden the car got power from somewere aand the dash lights became very bright. so im thinking this wire may be causing my problem
Tony123 is offline
Old 08-02-2010   #22
More likely a coincidence, the heater circuit isn't enough on its own to prevent the car from starting. Very bright lights suggest the generator voltage regulator isn't doing regulating things and likely to burn things out. If so, you could end up with blown electronics as well as a cooked battery. Get it professionally tested before you bills go any higher.
WhiteSei is offline
Old 08-02-2010   #23
Have had a problem with third party radio/CD (Cheap Aldi radio CD). Appears that Fiat radio cassette had some sort of time out device which closed it down on turning the ignition off. The Aldi equipment kept drawing power and would cause starting problems. Local electrician changed power supply to run through ignition switch which solved the problem. Check for current flow through Earth lead when ignition switched off. Cost £30 at local auto electrician found in yellow pages.
al68 is offline
Old 09-02-2010   #24
oo ill give that a go.. didnt think about the stero. had it in for over a year and only just started getting problems now.
Tony123 is offline
Old 09-02-2010   #25
A generator that loses its rectifier will show the charging light - a.c. wont charge a d.c.system.
If the voltage regulator has failed you could be getting 20V or more rammed into the battery. The battery will hold the voltage down - for a while but it will overheat and very soon be scrap.
Get the system properly tested.
WhiteSei is offline
Old 09-02-2010   #26
Once you go Burple
rallycinq's Avatar
Trader Rating: 1
Is this the test with the single jump lead?
SPD
Old 09-02-2010   #27
Once you go Burple
rallycinq's Avatar
Trader Rating: 1
OP tested system as above/below. Siad he was getting about 14 volts, which I think is fine.
SPD
Old 11-02-2010   #28
SPD
yer.. i put the black jump cable from my mums battery neg to mine
since unpluggin my heater motor the car has started first time in the past 3 days so im thinkin its that.
Whats weird tho the knob which you turn to were the air comes out (ie feet, windows ect) was getting stuck on something. since unpluggin the motor that knob is now spinning round freely like it supposed to.. Quite bezar IMO lol
I think i just realised why its only chargin at 14v and not say 14.5v and i think its because ive got a high maintenance battery on so my alternator isnt quite big enough to give it that bit more charge.
Tony123 is offline
Old 11-02-2010   #29
Once you go Burple
rallycinq's Avatar
Trader Rating: 1
Doh, single jump lead is from your car battery earth to the engine block, but your earth connection on the battery must be clean and tightened to 'ft'.
The connector for your heater isn't trapping the flap is it?
SPD
Old 11-02-2010   #30
whats the flap?
when i bought the car, the middle controller was snapped so me and my dad tried to fix it.. and i think that we may have caused a perminant feed to it cause its still broke and to turn the heater on you had to try and it too catch to the switch too turn it of if you get what i mean.
Tony123 is offline
(G) Battery dead makki123 Punto 3 09-01-2010 20:52
(G) My Battery is dead already cookie9995 Punto 33 05-08-2008 20:59
(G) I think my car battery is dead, but what should I do now? michaelborello Punto 7 26-11-2007 21:55
(T) dead battery :-) rocky_punto Punto 12 19-02-2007 22:48
(T) Battery Dead??? mdsremos Cinquecento / Seicento 3 28-10-2004 12:42
Copyright ©2002 - 2010 FIAT Forum
