The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
FIAT Auto Specialist Team
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 04-02-2010   #1
Dan Ox has donated!
Engine cut at low revs
Hi I have a 1.2 2002 Punto. The head gasket recently blew having had that repaired I now have another problem. When I am accelerating and reach what I consider to be not excessive revs, the power cuts (engine continues to run) and the engine management light shows. If I change up at this point I can accelerate again. This problem happens in every gear and means that accelerating can take a long time (longer than normal!!).
Although not mechanically minded, I do realise that engines have rev limiters. This model does not have a rev counter so I can't give you an indication of when this is happening, but it is lower than normal.
Just wondered if anyone had any ideas?? Thanks
Dan Ox is offline
Old 04-02-2010   #2
Re: Engine cut at low revs
Does it make a strange noise when you accelerate? Or a different noise to normal?
Please click Thanks if you were satisified with the quality of my post.
www.petrolprices.com -
Search UK Petrol Prices for free on PetrolPrices.com
PuntoSS is offline
Old 04-02-2010   #3
Do a compression test and if that is fine, then sounds like an air intake issue, check you airbox for cracks, holes, check it has a secure fitting with the throttle body and breather pipe is on
A car can massage organs which no masseur can reach!
bredsticz is offline
Old 04-02-2010   #4
Dan Ox has donated!
There isn't any different noise to normal.
As I said I am not mechanically minded so not sure about doing a 'compression test'? Are you able to explain?
Dan Ox is offline
Old 04-02-2010   #5
Need a compression tester dial, disconnect ecu by 2 clips at the back of engine, screw it into spark plug holes and try to start the engine reading the dial! Shows you how much pressure you get from each cylinder and basically if any power is being lost from the engine. All while the engine is at operating temperature I might add
Old 04-02-2010   #6
Bugs Beware!!
Spentona has donated!
Add Like Mad Champion, Badger Race Champion, Bumper Golf Champion, Smaugs Treasure Champion, Valentine Surprizes Champion
Could also be a faulty sensor. (Crank sensor? dont know if the Mk2s have a cam sensor)
I believe that when it gets to a certain revs it stops reading puts it into limp mode causing the problems, when you change up it lowers the revs, the sensor reads again and the fault clears.
Might be worth getting the fault codes read.
WHEN GOD SAID SIX PACKS I THOUGHT HE MEANT BEER, SO I ASKED FOR A KEG
THE ONLY THING I CAN SEE MY TAXES BEING SPENT ON IS MORE WAYS TO TAX ME
Spentona is offline
Old 05-02-2010   #7
Some mk2 have a cam sensor some don't, I think most pre 2000 engines didn't have it!
Old 08-02-2010   #8
Dan Ox has donated!
Thanks for the help, think I will get it looked at and get the codes read.
Dan Ox is offline
(T) 1.6 with low revs and jittery idling engine - any ideas? roccamena sal Stilo 5 13-05-2009 18:21
(G) A story on low power at low revs, smoke, stalling, low mpg / EGR MJET sporting steedy87 Grande Punto 7 15-04-2009 14:10
(T) 1.1 engine low power in low revs amitoha23 Cinquecento / Seicento 19 14-10-2007 18:15
(T) gas cut and engine Died when low gear alexyusuperman Stilo 4 17-07-2006 22:08
(T) Engine misfire at low revs R Clarke Bravo / Brava 4 31-07-2003 16:13
Copyright ©2002 - 2010 FIAT Forum
