The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 17-07-2003   #1
Horn stopped working - fuse?
Yesterday I was driving home as usual, when the car in front braked to a stop opposite a right turn into a car park. No signals, but then someone got out. I was giving them a quick "why don't you tell me what you're doing!" beep on the horn, except it went more like 'b'. Further attempts at sounding it gave no sound. Most annoying since later in the journey I needed it, and again this morning! Now that I rely on the horn in my Punto (on my previous Astra I never got the horn to sound - lack of need and hard to operate!), I want to fix it.
Has anyone had this porblem before or have I just used the horn too much and it's knackered? If it were to need replacing where could I get a truck like prrraafff one? Oh, and is the horn part of the MOT?
Punto Mk2 ELX
Gav is offline
Old 18-07-2003   #2
The horn is part of the MOT.
You can buy airhorn kits from most car shops and Halfords.
Could be a loose wire, blown fuse or a knackered horn. Its quite easy to check with a multimeter.
Evil-Punto is offline
Old 18-07-2003   #3
Cheers, I checked it with a meter and found that it is the horn unit and the rest of the system seems fine. I'm about to go down to halfords and check out thier range.
Punto Mk2 ELX
Gav is offline
Old 18-07-2003   #4
Donz has donated!
i believe they have a bog standard replacement horn for £10 - £20, i was conisdering replaceing the squeeker fiat like to put in the sei a while back, but never got round to it :(
SEI POWER
NOS Guzzlers are just lower beings :D
Donz is offline
Old 18-07-2003   #5
HP. has donated!
Halfords do a 2 tone one (red with chrome bits - how odd - you're not gonna see it anyway) for about £20 I believe. I got my 2 tone setup from a scrapper, £2 a horn :D
oooooohh yes. I am a tight arse:)
Pete.
Cinq sporting 1242cc
Cinqs&Seis Yahoo group
Clubcento
HP. is offline
Old 19-07-2003   #6
Tell us if it all works OK Gav.
Old 25-07-2003   #7
Pickuped the single tone Halford jobbie. Same make as the original one (Flamm), also made in Italy, slightly different design and it fitted easily. Works fine, and surprisingly now I have it haven't need to use it!
Punto Mk2 ELX
Gav is offline
Old 26-07-2003   #8
Sorted, good show.
Old 21-09-2007   #9
Re: Horn stopped working - fuse?
mine did the same when i press horn there is a clicking noise from relay unit 20a i swapped this and it does the same any ideas!
allandarley is offline
Old 21-09-2007   #10
Xen
FFFTW!
Xen's Avatar
Xen has donated!
is power actually getting to the horn itself? get a multimeter on it. Mk2 horns are known to fail due to water ingress.
oh and the clicking relay... its should click as you press the horn and again when you release it, is this happening?
Xen is offline
Old 28-09-2009   #11
Hello, i know im picking up from an old thread and i really hope someone replies . Mine has never worked since i bought the car a month ago, it doesnt click when i press it in, it does nothing and i checked the fuse and thats fine too. How would you go about using a multimeter and what do they do?
Thanks .
Rick01 is offline
Old 28-09-2009   #12
is rather bored
The Unknown's Avatar
The Unknown has donated!
Wak the Sak Champion
measures voltages or currents
link may be a high or a low price
http://www.maplin.co.uk/Module.aspx?ModuleNo=25414
basically select 50 volts and get a mate to hold it across horn terminals while you push down if it moves there is voltage going to it and if it moves switich is working
or is voltage a serial connection
or select amps about 150 if it has it to be on safe side (if car batteries push that much)
support fiat forum http://fiat-forum.myminicity.com/ add ind sec tra env accordingly to end for other things
Originally Posted by Stu DemonD
Is size important to you?
The Unknown is offline
Old 30-09-2009   #13
Xen
FFFTW!
Xen's Avatar
Xen has donated!
Thanks .
The relay click would be very quiet anyway. The horn is located under the bonnet, right up at the front near the drivers side headlamp on a bracket. Theres a push on connector for it... pull it off. Set your meter to DC Voltage (sometimes indicated with a V and a horizontal line with 3 dots underneath it.) There will usually be several DC voltage settings, so pick one that is greater than 12v. If your unsure, the assistant at the shop will be able to tell you where to set the meter to test for 12 volts DC. Stick one needle in one terminal in the connector and the other in the other. Then have a friend press the horn whilst you check for a reading. If the display stays at zero, theres a problem with the circuit. If it reads 12 or so, your horns had it (which usually is the problem.) Just replace the horn. simple bolt off, bolt on job
Yeh, you measure the voltage directly off the terminals.
Were not really concerned with the current, just making sure were actually getting something at the horn contacts.
and yup, car batteries will push 150amps no problem Even the smaller batteries like the 002/202 used in a punto will push out 350+ easily. Most meters only measure to 10amps anyway.
Xen is offline
(T) Blown Indicator Fuse klaus23 Punto 2 19-08-2009 03:14
(T) horn not working kopite Bravo / Brava 1 22-07-2004 01:52
(T) Horn BEEEPPPPPPPPPP Lemzip Punto 5 29-06-2004 14:39
(T) Rear Window wash not working Scorg Bravo / Brava 5 23-04-2004 04:58
(S) Air Horn Upgrade Cusim Cinquecento / Seicento 2 13-03-2004 23:32
Copyright ©2002 - 2010 FIAT Forum
