- Jan 20, 2013
- 6,151
- 1,228
is it possible that wrong fuel is in?
Lambda can make EML come on yes - hence the fact the ecu logged the error before... It can put eml up because its gone completely open circuit (i.e. totally failed and not getting a signal from it) or could do that from a wiring fault rather than the actual sensor failure. Remember the light is just an engine management light and has nothing to do with injectors per say but if you have another known working TB then swap the whole lot as that also rules out any of the little sensors on it, TPS, ICV, AIT.....
the injector can be taken out and swapped but there is little point - the injector itself failing I have never heard of. But you could try taking the whole TB you have spare and sticking that on.
plugs dark? as in all sooty and black on the electrodes? did you clean them up before you stuck them back in??
Mmmmm, indicative of running rich. Try cleaning them up and re-gapping them (0.9mm from memory but look it up) - see if that makes it start and idle better - and if it does do resistance test on the coolant temp sensor
Have you put the crank pully in the right position?
