| Hi there Just got me a Punto... and have found that I have no reverse lights - I have checked the bulbs and they are fine - just swapped them with the brake bulbs. Checked all the fuses and they are fine.... was then thinking that it might be some switch on the gearshift - so I lifted that and cant see any switch - there seems to be a cable running up into the back of somewhere that gets pulled when you put it into reverse so dont know if this activates a switch. I have the Haynes repair manual but cant find anything relevant in this... Any help would be appreciated! Cheers pmcq
| Have you tried using a multimeter to see if any juice is getting there at all? Why do you need a reversing light? Just turn the car around and drive the other way! Sorry!
__________________ Black MK1 Punto Sporting | |||
| | #3 | ||
| Join Date: Oct 2003 Location: buxton the land that time forgot
Thanks: 1 Trader Rating: (0) | Re: Help! No reverse lights! i dont know what punto you have but if its a mk2 then goto chapter 7 part A number 7 reversing switch testing,removal and reffitiing. if its mk1 manual than should be in the manual transmision section of the manual
__________________ 2001 Punto sporting in sprint blue with 2 Mr Bump air freshners and a new clutch and flywheel mmmm | ||
| | #4 | ||
| Re: Help! No reverse lights! Thanks guys - I'll give that a go...
| Reverse lights not working! | vfourracer | Tipo | 4 | 23-11-2004 11:53 |
| Reverse Lights won't Work | markwartd | Punto > Technical | 8 | 30-08-2004 16:02 |
| Cant get in reverse | Shakey | Cinq/Sei > Technical | 9 | 28-05-2004 03:52 |
| Reverse lights dont work & Wet Windows | slf_16 | Punto > Technical | 10 | 08-02-2004 05:34 |
| Brake lights sort of not working...sometimes | Sando | Cinq/Sei > Technical | 2 | 18-11-2003 05:47 |
