Posts: 10 Thanks: 0 Trader Rating: 0 | come off the motorway friday and my punto MK2 y reg (2000) 1.2 8v just cut out and wouldn't re start. recovery man said fuel pump seized.. it hadn't we've bought 2 more since then and now it seems no electric is getting to the pump. HELP ANY IDEAS i here it could be the fuel pump relay, where is this, is it easy to fix(how), cost etc??? fuses seem fine could be a cut off switch we are told under carpet in passenger foot well. now someone says engine crank sensor.. again what is it what would the problem be, ho fixed , cost etc NEED ADVICE ASAP... PLEASE ANYBODY... WE KNOW NOTHING ABOUT CARS OUR FATE RESTS WITH YOU
Posts: 2,084 Thanks: 186 Trader Rating: 4 | Re: Fuel pump not working punto mk2 y reg 1.2 8v Did you check the cut off isn't depressed?
__________________ Need alloy wheel spacers or bolts? PM me! | ||
| | #3 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v does the cut off switch need to up or down
| | #4 | ||
Posts: 2,084 Thanks: 186 Trader Rating: 4 | Re: Fuel pump not working punto mk2 y reg 1.2 8v It should be level, depressed means it's cut off iirc.
| | #5 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v so how do i reset it
| | #6 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v So how do i reset fuel the cut off
| | #7 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | How do i reset the fuel cut off. PUNTO MK2 1.2 8V Y REG How oh how
| | #8 | ||
| | Re: How do i reset the fuel cut off. PUNTO MK2 1.2 8V Y REG youve pressed the cutoff swich on the passenger side? | ||
| | #9 | ||
Posts: 1,884 Thanks: 66 Trader Rating: 0 Drives: | Re: How do i reset the fuel cut off. PUNTO MK2 1.2 8V Y REG There is a button on the sill by the passenger seat, press it. If it is pressed down already it was cut off. If it presses down when you press it and comes back up again it was never cut-off.
__________________ | ||
| | #10 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | Re: How do i reset the fuel cut off. PUNTO MK2 1.2 8V Y REG So if it was down how does it reset
| | #11 | ||
Posts: 171 Thanks: 8 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v It pops up when its cut the earth to the pump, you push it down to reset it (if it will reset, mine was knackered and would'nt). You can test it by shorting the two wires out to prove it (take the conector off the bottom and connect the two wires together). Obviously fit a new one though if it is faulty, its a safety feature.
| | #12 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v I seem to be having a similar problem on a y reg 1.2 16v - although it was taken to a local garage by the RAC. Car starts if power is applied directly to fuel pump, but won't start normally. At first a break in the circuit between the fuse & the relay was hinted at but the mechanic has checked all this out & reckons it's a bad earth somewhere. Does this sound feasable - how is it resolved?
| | #13 | ||
Posts: 171 Thanks: 8 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v If putting 12v's to the pump fixes it then its not the earth.
| | #14 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v Thanks for the reply. The car was fine on Friday, came to start it on Monday morning & it was dead - turning over but not firing, no petrol getting through. As mentioned, the RAC man started it by running power direct to petrol pump. Any ideas what it could be?
| | #15 | ||
Posts: 23,516 Thanks: 713 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v I have came across this on a number of occasions (if its the fault i'm thinking it is), my suggestion would be tow it to a dealer once you have checked the basics.
| Tags |
| crank sensor, cut out switch, fuel pump relay, fuel pump switch, punto, punto 1.2 |
| | beau | Punto | 18 | 17-03-2008 15:54 |
| | Dunc Uno Turbo | Uno | 7 | 17-06-2007 17:41 |
| Fuel Pump (not working?) | jamgeo | Bodyshop | 1 | 08-04-2006 17:44 |
| fuel pump & spark plugs not working | tjs | Lets Talk FIAT | 6 | 01-04-2005 23:25 |
