| | #16 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v I'm not in a position to take it to a dealer as it's already with a mechanic - the RAC man got it started & followed me down to a local garage (where I usually get any repairs/mot/servicing etc done). What was the problem/fix on the occasions in the past?
| | #17 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v Can anyone else offer advice as to what may be causing this fault? Thanks.
| | #18 | ||
Posts: 10 Thanks: 0 Trader Rating: 0 | no power getting to the fuel pump
| | #19 | ||
Posts: 198 Thanks: 10 Trader Rating: 0 | Re: is it the crank sensor (yreg punto mk 2 1.2 8v) Won't be the crank sensor causing it, since the fuel pump is activated for 2 seconds to pressurise the line when you switch the ignition to 'on' you should be able to hear it whirring when you twist the key.
| | #20 | ||
Posts: 549 Thanks: 43 Trader Rating: 0 Drives: | Re: is it the crank sensor (yreg punto mk 2 1.2 8v) A faulty crank sensor would either mean the car wouldn't start, or you'd get the EML dash light and if not that the car would play up with starting sometimes. To be honest you should hear the fuel pump kicking in, as mentioned above. If not check your fuel relay!
__________________ ![]() STATUS: LED PROJECT & ALPINE MULTI-MEDIA MOBILE STATION. TO COME: PECO BACKBOX TO BE FITTED + CUSTOM A/F + SERVICE LOOKING FOR: N/S WING BROOM YELLOW + ANGEL EYES, TINTED REAR LIGHTS. | ||
| | #21 | ||
Posts: 23,516 Thanks: 713 Trader Rating: 0 | Re: is it the crank sensor (yreg punto mk 2 1.2 8v) you have already posted this twice, maybe members just dont know the answer or you will need to take it to a garage like already suggested.
__________________ | ||
| | #22 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v Turns out it was the inertia fuel cut off switch that had gone faulty.
| | #23 | ||
Posts: 171 Thanks: 8 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v So how did putting 12v's directly to the pump work then? There would of been no earth?
| | #24 | ||
Posts: 23,516 Thanks: 713 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v Unless they bridged it out?
| | #25 | ||
| | #26 | ||
Posts: 13 Thanks: 0 Trader Rating: 0 | Re: Fuel pump not working punto mk2 y reg 1.2 8v Same thing happened again yesterday, car started fine in the morning then went into town, when I came back to it it wouldn't start. RAC man (same chap as last time) had a look & deduced that it was the fuel cut off switch (this time the thing just wouldn't reset) - Got it started & took it to garage. Mechanic has come to the conclusion at either he was very unlucky in putting a dodgy switch in, or something is making it go (he suspects the fuel pump giving it too much current). He's put another fuel switch on for now as this is cheaper than replacing the fuel pump(& finding out that it's not that) - will see how this goes. Anyone else had similar experience of this type of fault, any comments?
| Tags |
| crank sensor, cut out switch, fuel pump relay, fuel pump switch, punto, punto 1.2 |
| | beau | Punto | 18 | 17-03-2008 15:54 |
| | Dunc Uno Turbo | Uno | 7 | 17-06-2007 17:41 |
| Fuel Pump (not working?) | jamgeo | Bodyshop | 1 | 08-04-2006 17:44 |
| fuel pump & spark plugs not working | tjs | Lets Talk FIAT | 6 | 01-04-2005 23:25 |
