The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
FIAT Auto Specialist Team
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 27-04-2009   #1
Help diagnosing problem
Hi everyone
Owner of a 2000 W base model Punto for the last couple of weeks. Been generally fine!
However ... I drove it yesterday while fully loaded (four people and a reasonable amount of baggage) and sometimes whilst pulling away from a standstill in first there was a slight sticking/jerking with an accompanying noise.
Don't think it is this brakes as I tried coasting to a halt and it still did it, also don't think it is the suspension/exhaust bottoming out, nothing seems to be hanging from the exhaust and the car wasn't riding that low.
Am I suffering from the clutch problem that many people seem to have with their puntos (something to do with the clutch release?), how do I check? It is strange because as soon as everyone got out, I could not recreate the problem.
Thanks in advance!
p.s. no idea whether it happens pulling off in all gears, only tried first and can't recreate the problem without a full car
sidewinder77 is offline
Old 27-04-2009   #2
Re: Help diagnosing problem
Check that you can see no marks on the rar axle beam where the exhaust has been rubbing on it have seen this before and it only happens when the motor is loaded if you see marks then its probably a non fiat exhaust
clutch judder is common on the 188 puntos.
daza001 is offline
Old 27-04-2009   #3
Thanks daza, will check tonight, if this is the case, is there a fix?
Old 29-05-2009   #4
I had this problem for a while and found out it was the exhaust rubbing on something. It stopped after I fitted my own exhaust collar that held it in place slightly closer to the bottom of the car. Only costs £2 or £3 from Halfords.
flumpy is offline
Old 19-11-2009   #5
Just to say thanks, it was a problem with the exhaust alignment, got sorted at a service, the part that was causing the noise was blowing and thus had to be replaced anyway!
Tags
jerking, noise, pulling away, punto
(T) diagnosing faults on non EFI engines arc Panda (Classic) 4 23-04-2009 19:43
(T) Diagnosing a misfire Eklipze3k Cinquecento / Seicento 4 20-04-2009 19:42
(T) Stilo electrical problem + warm starting problem h2ypr Stilo 19 11-02-2009 17:35
(T) Overheating Problem/Head Gasket Problem droodroo Punto 17 19-03-2007 14:00
(G) Problem after Problem.. Dealers, Faults, Seats, Vents, Paddle... the list goes on! Bootlegdj Stilo 19 25-04-2006 08:18
Copyright ©2002 - 2010 FIAT Forum
