Evening all, fitted a new sump tank to the car over the weekend due to the old one being past rotten. This has cured the main leak off the sump tank but imagine my jubilation to come back to the car this evening for the drive home to find a nice small pool of oil formed under the gear box (about the size of a CD) and a smaller patch next to it consisting of coolant (about the size of the bottom of a drinks can).
There isnt any visable leak on any of the coolant pipe's and it appears to be coming through one of the metal pipes attached to the block, any suggestions on what to do there? paint and pray?
On the oil side of life the fly wheel cover has oil over it and the oil has run off there down the bottom of the gearbox and dripped. The oil level has dropped from MAX 2/3 of the way down towards MIN (some obviously had to go in to circulate from the whole system getting drained out) and I can't see any run/drip marks down the sump at all. Obviously it's dark and havent checked the back of the sump other than with a hand; but any ideas as to where else this could come from before I start pulling the sump off to re-seat it are welcome. Or any ideas as to how to find out where the leak is coming from if it isn't visually aparent.
Thanks!
Thanks!
