The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 07-08-2008   #1
Trader Rating: (0)
Fuse keeps blowing
one of the 2 radiator fans on my hgt stopped working. I checked the fuse for FAN1 and it was blown so i replace with a new one.
A day later the fan isn't working again and the fuse has blown again so i replace it again.
Now today this fuse has blown aswell and the fan isn't working again leaving only 1 fan to cool the engine which is overheating a little.
Any idea what could keep causing the fuse to keep blowing? it's very annoying not to mention costly.
easyrider81 is offline
Old 07-08-2008   #2
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: Fuse keeps blowing
probably seized fan
T14086 is offline
Old 07-08-2008   #3
Trader Rating: (0)
Originally Posted by T14086 View Post
probably seized fan
Oh right is that the motor or the whole fan that needs changing?
Old 08-08-2008   #4
He Who Dares Wins
marty61's Avatar
Trader Rating: (0)
marty61 has donated! United Kingdom
With engine cold and ignition off spin both fans by hand and see if they both spin freely. If they do then problem is most likely in the wiring/connections. Check all connections are secure, clean and dry and that the wiring is undamaged and not chafing on anything. Breakers yard would be a good source for a fan/motor if you do need one.
06 GP 1.2 Active - 3 Door - Bolero Red.
"If it ain't broke, it ain't a Fiat"
ALL THANKS GRATEFULLY RECEIVED
marty61 is offline
Old 08-08-2008   #5
T14086's Avatar
Trader Rating: (0)
comes as whole assembly (£85 / 112 odd) depending on type.
T14086 is offline
Old 10-08-2008   #6
Trader Rating: (0)
thanks for the replies.
looked at the wiring and seemed fine. Bought a new 30a relay for the fan in the fusebox and seems to be alright now, see how it's goes.
Old 10-08-2008   #7
T14086's Avatar
Trader Rating: (0)
fuses blow for a reason, why not start up car & let it idle until temp guage reaches halfway where the cooling fan should cut in, if it dont & fuse blown again then you know the problem.
T14086 is offline
(T) Fuse keeps blowing ShadowUK Bravo / Brava 6 13-05-2008 15:44
fuse blowing bunny11uk Ducato 0 14-04-2008 22:39
(G) Fuse keeps blowing s786m Cinquecento / Seicento 9 20-03-2008 09:17
(T) fuse blowing??? brazzy2k1 Bravo / Brava 0 18-06-2004 04:35
