| | #16 | ||
| Re: Taking the battery out of my MK1 ye the battery is connected right, if it is fully charged the car seems want to turn over but then just cuts out, any tips on how to start it ?
| | #17 | ||
| Re: Taking the battery out of my MK1 Immobiliser maybe? Does the CODE light go out?
__________________ | |||
| | #18 | ||
| Re: Taking the battery out of my MK1 ye the code light goes out
| | #19 | ||
| Re: Taking the battery out of my MK1 Take the battery out again. Do it as posted. Charge the battery for say 4hr Put it in again as posted.
| | #20 | ||
| Re: Taking the battery out of my MK1 ive done that, but the engine still won't start, it sounds like its about to for the first couple of times and then nothing, and when i check the battery its dead again
| | #21 | ||
| Re: Taking the battery out of my MK1 Try it with a new/fresh battery or if you can try to jump start it - by the sounds of it the battery sounds like it's dead if it can't hold a charge.
| | #22 | ||
| Re: Taking the battery out of my MK1 if the battery won't hold a charge will a jump start still make the car go, untill i can get it to a garage ?
| | #23 | ||
| Re: Taking the battery out of my MK1 Yes, the purpose of the alternator is to supply enough electricity for the engine to work and to charge the battery. It should be enough to get to the battery shop or garage.
| The following user says "Thank You!" to dj_jl for this useful post: | ||
cookie9995 (02-08-2008) | ||
| | #24 | ||
| Re: Taking the battery out of my MK1 Thanks, so do all the problems like the light going dim when i try to start the car and the car sounding like it wants to start when the battery is fully charged ??
| | #25 | ||
| Re: Taking the battery out of my MK1 Yep I'd say it's the battery - try another in it before you take it to a garage. Lights dimming certainly sounds like it hasn't enough charge to turn itself over.
| | #26 | ||
| Re: Taking the battery out of my MK1 how much will a new battery for it cost ?
| | #27 | ||
| Re: Taking the battery out of my MK1 I have just bought a battery booster, will this start the car if the problem is the alternator or the battery ??
| | #28 | ||
| Re: Taking the battery out of my MK1 Right well the car won't start with the booster, does anyone know what the problem could be ?
| | #29 | ||
| Re: Taking the battery out of my MK1 Try starting with jump leads, connect leads in correct order etc. If car does start.........get a new battery or have the battery tested. New battery should be about £35ish
| | #30 | ||
| Re: Taking the battery out of my MK1 right, i think that it is not the battery now, because both the booster and jump starting the car won't work so i am starting to think it is the alternator. How much am i looking at to get a new one and to fit it ???
| | newstor | Punto | 12 | 12-07-2007 21:16 |
| | jaysenysen | Punto | 6 | 29-01-2007 16:19 |
| | damselindistress | Marea | 1 | 13-11-2006 16:52 |
| | Metro_vvc | Uno | 8 | 29-01-2006 00:57 |
| | beau | Punto | 4 | 04-11-2005 00:09 |
