The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 15-07-2008   #1
Trader Rating: (0)
Question Overheating,headgasket?
Hi guys, my Mk1 Punto 60s overheated at high speed last night. I pulled over and checked the coolant level, it appeared to be way below the min line. So topped it up with some bottled water and drove another 10 miles home with no problem. This morning I checked the oil filler cap and found no mayo and dipstick clean as well. No oil smell in the coolant and no white smoke from exhaust. Does it look like a blown HG? If not, why has the coolant level gone down (it was topped up this time last year). Many thanks in advance!
FePunto is offline
Old 15-07-2008   #2
Trader Rating: (0)
Re: Overheating,headgasket?
The coolant level does drop slightly over time through normal use.
I suggest you keep a close eye on it, check levels before/after each journey any sudden drops of coolant will point to HG failure.
You could get a sniff or compression test done if you wish at a garage but i would think this unnescersary at the moment as i think you just ran low on coolant. But keep an eye on it just to be on the safe side.
53 reg Mk2b 8v Lagoon Blue
UKT support
Mdeko is offline
The following user says "Thank You!" to Mdeko for this useful post:
FePunto (16-07-2008)
Old 16-07-2008   #3
oh my gentle jesus
Rich_65402's Avatar
Trader Rating: (0)
Rich_65402 has donated! United Kingdom
Fiat Punto Active Sport
Rich_65402 is offline
The following user says "Thank You!" to Rich_65402 for this useful post:
Old 16-07-2008   #4
Trader Rating: (0)
Thanks Mdeko, that's good news for me!
FePunto is offline
Old 16-07-2008   #5
Panda's with Gadget's
Most Easterly Pandas's Avatar
Trader Rating: (0)
Most Easterly Pandas has donated! United Kingdom
Why does one who confirmed what the other said get the thank you button pressed, and the one who said it in the first place dosen't
Most Easterly Panda's - Panda'ing in East Anglia
5 Panda's! 1989 F-reg 750L, 1991/1992 (not sure as on a NI plate) Panda 1000CL,
1993 K-reg Selecta (1108cc) x2! 1988 E-reg Sisley 4x4
Originally Posted by Jai View Post
grip the meat, loosen the throat, relax and slide it in
If my post or someone else's has helped, say thank you using the Thanks Button \/
Most Easterly Pandas is offline
The following user says "Thank You!" to Most Easterly Pandas for this useful post:
Old 16-07-2008   #6
Trader Rating: (0)
Hi, thanks for reminding me. Now both buttons together with yours have been pushed!
FePunto is offline
Old 16-07-2008   #7
Trader Rating: (0)
Lol. Ta
vB code is On
headgasket needspeed Cinquecento / Seicento 6 10-02-2008 00:00
headgasket Gorman1981 Punto > Technical 4 01-09-2006 19:27
Headgasket? Zorro Punto > Technical 1 05-05-2006 16:06
headgasket skinnyvinny Cinquecento / Seicento 15 19-03-2006 20:31
headgasket philbo Cinq/Sei > Technical 12 05-10-2005 14:54
