| Brake Lights Hi All, I'm a girl with a 1995 punto 75, with no brake lights and no user manual. It's not the bulbs (even though I had to tip about 3 litres of water from the lighting cluster) so I'm assuming it's a fuse. However, I can't find the bleeding fuse panel! Please help me! x
| Re: Brake Lights could of well short circuited and tripped the fuse Make sure tho that u check the bulbs are dry and they are making good contact - as the water also have corroded the connectors And fuse box should be in a pannel near ur right nea - been a RHD Yahoo says " The fuses are behind the small recess in the dashboard below and right of the steering wheel in right hand drive." Ziggy
| The following user says "Thank You!" to Ziggy122 for this useful post: | ||
Chrissy B (11-07-2008) | ||
| | #3 | ||
| Re: Brake Lights Hi there Under the steering wheel to the right, theres a little panel with two cross head screws. I think its like a little oddment tray. Anyway, when you open the panel, it should be either the middle fuse in the top row, or the middle fuse on the bottom row and according to the manual, its a 15A fuse. Hope this is some help to you and good luck.
| | #4 | ||
| Re: Brake Lights Cheers guys - found fuse panel, but now have to work out which one it is! Not middle top or middle bottom - they are marked as Fog lights and 'service' (?) any ideas?
| | #5 | ||
| Re: Brake Lights Hi The one named "Servizi/Services" is the one. It covers the a whole range of stuff including the brake lights and reverse lights and the indicators etc...
| The following user says "Thank You!" to Punto_2008 for this useful post: | ||
| | #6 | ||
| Re: Brake Lights Oh. I thought it would be something to do with the stereo. Oops. Righty ho - off to Halfords I go. Bit strange though - all other lights are fine - indicators, reverse lights etc....
| | #7 | ||
| Re: Brake Lights Ah right, its probably not the fuse then. You should be able to tell if you take the fuse out and have a look in the middle as you can usually see the fuse wire running through the middle. Is it just that light cluster or have both of the brake lights gone?
| | #8 | ||
| Technician | Re: Brake Lights Hi, If all the fuses, bulbs etc are ok, then next step would be to look at the brake light switch itself. Alan
__________________ ![]() Seicento Sporting 1.1, Punto 1.9 JTD, Punto 1.3 Multijet, Bravo T-Jet 150 Sport, Impreza STi PPP Links to guides - JTD Crank Sensor, Punto Juddering Wipers , JTD MAF sensor Bravo 198 Warning lights Bravo 198 Service Schedule | ||
| The following user says "Thank You!" to a1ant for this useful post: | ||
| | #9 | ||
| Re: Brake Lights Both brake lights gone - all other lights okay. Just off to try the fuse - can't see if it's gone so will try one of the shiny new ones i've just bought. What is a brake light switch?
| | #10 | ||
| Re: Brake Lights It's not a fuse. Did a search and found a few bits on here about brake light switches. Think i've found mine - a litle metal pressing thing resting on thr brake pedal. Pressed it in and out okay so it isn't stuck, is there a way to take it out and test it?
| | #11 | ||
| Technician | Re: Brake Lights Have you got a multimeter?
| | #12 | ||
| Re: Brake Lights No. Just a gas meter ![]() Probably best go to the garage then i guess... Never mind, was getting quite excited about fixing something myself.
| | #13 | ||
| Re: Brake Lights Apparently my other half's Dad may have one..... What do I do? Apologies for using this forum like a reference book - but with so much knowledge about i'd be daft not to try and get tips!
| | #14 | ||
| Technician | Re: Brake Lights Hi Disconnect the wiring plug from the switch. Set the multimeter to continuity (ie beeps when the two probes are put together etc) Put one probe in each connection on the switch, and then press the break pedal. The multemeter should show continuity when the switch is pressed. If not, the switch is dead. Alan
| | #15 | ||||||
| Re: Brake Lights if it is the brake light switch i will send you one if you send me a stamped addressed envelope got one in my old car
| Speedo, Brake Lights & Reverse Lights Not Working | cchheessyy | Cinq/Sei > Technical | 4 | 20-03-2008 23:43 |
| brake lights... | cinqy_smurf | Cinq/Sei > Technical | 5 | 26-02-2006 18:46 |
| brake lights - help please | zippeyrude | Tipo | 5 | 15-04-2005 18:41 |
| Cinq Sporting Electrical Problem - Brake lights/rear lights | namb | Cinq/Sei > Technical | 3 | 20-02-2005 17:00 |
| Brake Lights | Bob D Builder | Punto > Technical | 3 | 22-01-2004 04:58 |
