| Boot Lever! Hi all. I went to open my boot with the lever earlier, and nothing is happening? I presume its either broke or somethings come loose or something, given my knowledge on cars is appalling lol! Its a 98 Punto S so i was just wondering if anybody knows how to fix them or how to have a closer look? Cheers in advance Luke
| A Panda with Gadget's | Re: Boot Lever! I know they're totally different car, but same happened to my grandad's P-reg Escort Saloon, and it turned out just to be a little switch by the look in the boot which can be used to stop the leaver work, had just slipped accross, so we slipped it back and hay presto. ![]() Have a look to see if there is something similar in your Punto
__________________ Bright in White... Look at those spots and the 240 watt of 4 Halogen bulbs!If my post or someone else's has helped, say thank you using the Thanks Button \/ | ||
| | #3 | |||
| (I Love Brackets) | Re: Boot Lever!
does the lever feel light? and not like it used to? | |||
| | #4 | ||
| Re: Boot Lever! Thanks for the responses. Yes, it feels almost as if theirs no resistance when i pull the lever. It does feel very light. If it is a snapped cable, is it hard to correct? Cheers.
| | #5 | ||||||
| Re: Boot Lever! if you can still open the boot with your key then it will probably be a problem with the cable either snapped or more likely come out of a securing clip somewhere if the lock is now also stuck then what has happened is the little lever that operates the boot lock from the cable has become stuck across and not been puled back by the spring meaning it will be the wrong side of the lock when the boot is shut and wedges the hole thing solid or if someone is holding the boot lever up wile the boot is shut this will do the same thing if so you can pull down your rear seats and gain access to the inside of the boot you can open it buy pushing the lever with your fingers or undoing the bolts that hold the boot lock in place if it has become wedged in the way i suggested above
![]() Last edited by littlepip17 : 19-06-2008 at 17:59. | |||||||
| Bonet Lever | Sian09 | Punto > Technical | 5 | 22-04-2008 18:57 |
| help! autobox lever. | mickh | Punto > Technical | 3 | 28-01-2008 11:50 |
| boot warning lamp stays on-boot closed | phonecia1 | Stilo > Technical | 2 | 04-02-2007 14:46 |
| Electric boot release! Ideal for flush boot doors | brickfoot | Auction Watch | 1 | 06-09-2004 21:38 |
| boot lever | steve_d01 | Bravo/a > Technical | 2 | 29-05-2004 01:14 |
