| possible timing belt slip? Ok on way home i dwove though surfae water that turned out to be deeper than expected and slowed me from 50 to 30, com out he other side and it soulds awful my original thought was water in intake poss on the sparks should be fine shortly so i knocked it into third and put my foot down but nothgin happened just sounded really really bad. Looked under bonnet when i got home nd nothings out of place, was just wondering iffffffff The fact that the wheels got slowed down so much with the acellerator still trying to work couldthe timing belt have slipped? or could it just be the sparks are still wet. was about 2 mins from home and not tried it since cos it raining and dark. if neither of them could it be soemthing else? thanks
__________________ damn i love my car! ![]() | |||
| Likes his feet up | Re: possible timing belt slip? checked sark plug leads what go around engine n that leads n all that lot? i drove though a puddle and soaked my electrics got it above my car ![]() how high yours go? http://www.fiatforum.com/leisure-lou...-i-m-dope.html
__________________ ^Please excuse the above writing as it lacks English^ knows nothing about cars Punto mk2 1.2 8 valve 2000 Xreg silver | ||
| | #3 | ||
| A Panda with Gadget's | Re: possible timing belt slip? Won't be timing as you'd really know it. Probably just running on 3 or even 2 cylinders ![]() Let it dry out and hopefully all will be fine Jon.
__________________ Bright in White... Look at those spots and the 240 watt of 4 Halogen bulbs!If my post or someone else's has helped, say thank you using the Thanks Button \/ | ||
| | #4 | ||
| Likes his feet up | Re: possible timing belt slip? mine was running on 2 or 3 cylinders but the engine was shaking alot I'm sure it would be very noticeable but to scare yah ![]() could it be a cam rod? im no mechanic tho
__________________ ^Please excuse the above writing as it lacks English^ knows nothing about cars Punto mk2 1.2 8 valve 2000 Xreg silver Last edited by Daz_Rich : 18-06-2008 at 23:16. | ||
| | #5 | ||
| | #6 | ||
| Likes his feet up | Re: possible timing belt slip? i would bet electrics i think wd40 is good and a commpressor to spray out water and a few rags and dont let your mate do it spent ages cleaning the plugs out and he took all my leads off with no markings a month later i found my ait box wasnt tightened
| | #7 | |||
| A Panda with Gadget's | Re: possible timing belt slip? . FIRE engine seem to have been made to trap water around the plugs, so best bet is to check and blow out with an air line if you have one, as said above.Jon.
__________________ Bright in White... Look at those spots and the 240 watt of 4 Halogen bulbs!If my post or someone else's has helped, say thank you using the Thanks Button \/ | |||
| | #8 | ||
| Re: possible timing belt slip? yeah mine (98 60SX) used to do that every time I drove through a decent puddle when I first got it, had a 50 mile back road commute at the time so it happened pretty regularly. Scary stuff at the time and had to stop a few times until it dried out but new leads and a good clean and WD40 round the coil connections did the trick. Be fine in the morning.
| | #9 | ||
| Re: possible timing belt slip? yeah went out to start her up this mornin n its fine! no worries just had a little trouble starting, usually has no worries so its all good! ![]()
| | #10 | ||||||
| Re: possible timing belt slip? if you get new leads they will form tighter seal (arg arg ) around the plugs and couple this with a spray of wd and you'll never have another problem me thinks maybe an under tray would also be good does anyone know if the punto diesel has one us petrol heads could nick
| | #11 | ||
| Likes his feet up | Re: possible timing belt slip? me wants one of them under seals ![]() was gonna swrink wrap the entire car then i relised i would be unable to open a door
| DIY timing belt (cam belt) | shiningliao | Stilo > Technical | 10 | 27-01-2008 08:58 |
| Cam Belt / Timing Belt query. | amanda40 | Marea | 5 | 14-01-2008 22:09 |
| Timing belt/cam belt | tony316v1 | Punto | 11 | 08-01-2008 17:07 |
| For Sale: timing belt / aux belt / fuel filter 1.8 16v (FIAT Bravo / Brava) | jug | For Sale / Wanted | 0 | 07-09-2007 13:46 |
| tick tick timing slip | manic_monkey | Bravo / Brava | 11 | 08-03-2007 15:11 |
