The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 18-06-2008   #1
Trader Rating: (0)
No spark - punto gt
Hello
I have a problem with my Punto GT 95 mod (133 HP). I have no ignition, it just "died" when I drove it, silently with no noises or anything.
I've done a check however. All fuses are fine, found one cluster in the engine room, one in the coupe at the passenger side and one at the driver side. I measured zero voltage from the wire leading to the distributor, but I didn't find the coil leading to the distributor, it's hard for me when I lack the instruction manual(imported car). Does anyone know if I can download it somewhere?
Has anyone encountered this problem before? Are there hidden fuses for the ignition? Is the brain located in the coupe with a device to convert the voltage to high voltage for the spark plugs?
The car is very rare here in Norway, maybe 4 or 5 maks, so it's hard when nobody actually has a clue
Live for nothing or die for something
Fiat Punto GT
sirolsen84 is offline
Old 18-06-2008   #2
Trader Rating: (0)
Re: No spark - punto gt
If you've lost all power from the battery (i.e. lights don't work, indicators etc) then I doubt it will be a fuse (unless you've been unlucky and blown a load at once)
Could be one of the earthing straps that have come loose/gone rusty. If I remember correctly the main one on the GT is beneath the battery tray so you'll have to remove that to check.
It could of course be a simple as a flat battery - sorry to ask but have you checked this?
Hope this helps.
warwick1 is offline
Old 18-06-2008   #3
Trader Rating: (0)
The thing is, I can turn the key and chin (not sure of the word in english) the engine. As I turn the key the starter engine turns the eninge but I have no spark, so the battery must be ok. Maybe it's an Idea to check this earthing strip anyway?
Fiat Punto GT
Old 18-06-2008   #4
Trader Rating: (0)
Please! I still need help. I'm really a newbie:s
Fiat Punto GT
Old 19-06-2008   #5
Trader Rating: (0)
If the engine turns over (i think that's what you mean by "chin" ) then it won't be the battery or the earthing strap.
Take a spark plug out, connect the plug lead back up and get someone to turn the engine over to see if you do actually get a spark. If not, then try changing the ignition leads (you can buy off ebay) or coil (again you can get on ebay but more expensive). It is located at the front of the engine near the oil level dipstick.
If you are getting a spark then could be a fuel problem - but try the plugs first.
Hope this helps.
warwick1 is offline
Old 19-06-2008   #6
Trader Rating: (0)
I appreciate your answer warwick. I've allready checked the plugs, that's how I concluded there is no spark I just too be fix my moped you see
So the coil is located near the oil dipstick in the front huh. Can you tell me if the brain is in the coupe-passenger side-behind the cd-player?
Fiat Punto GT
Old 19-06-2008   #7
Trader Rating: (0)
No problem.
By "brain" I presume you mean ECU (electronic control unit)? If so, it is located under the grille where the front windscreen wipers are - you have to take the wipers off to get to it.
Cheers.
warwick1 is offline
Old 19-06-2008   #8
littlepip17's Avatar
Trader Rating: (0)
ok well first check that the code light and injection light are doing what they normally do on the dash as you turn on the ignition
code light small yellow key should go out after 0.7 of a second
engine warning light red injector shape should go out after a few seconds
if this is so then the ecus are working
after this you need to check the live feed to the coil with a test meter prope the pins on the plug to the ignition coil till you find a live 12v
to find the coil flow the king lead centre lead from the distributor
if there is a live then there is no spark simply because the ecu is not triggering the coil or there is a fault with the wire from coil to ecu for the earth
it's most likely that the crank sensor on the engine has failed so the ecu cannot determine when to spark
these will cost you about 30 uk pounds and fitting is easy one 10mm bolt normally
i'm not to sure were they are on the GT model but they are located close up to a ring of some sort with lots of lumps and gaps on and then one longer lump in one place normally at the cam belt (or front) end of the engine
Originally Posted by j1ppers View Post
i had a car crash once in my mates car and it knocked me out when i woke up his knob was up my arse .
Originally Posted by dave View Post
its more important to get the penetration right before you worry about how it looks
GOD of the the 5 Door Liberation Front
littlepip17 is offline
Old 20-06-2008   #9
Trader Rating: (0)
Funny you should mention that littlepip17, I've had the red injection light since I bought it. A friend of mine with experience said the light could come and go, so I waited it out. What does it mean exactly?
We measured the resistance in the crank sensor wire to be 840 Ohms, but we didn't have any literature on it.
Thanks both...
Fiat Punto GT
Old 20-06-2008   #10
Trader Rating: (0)
It means a fault has been registered and stored with the ECU. The fault could relate to any of the sensors.
On the GT the light will not go out until a few seconds after the car has been started - but it should go out. It does come and go intermittently as the ECU registers a fault and then clears the problem itself. Fiat dealer told me the diagnostic system on early GT's is too sensitive - why the reason the light comes and goes.
Hope you sort it.
warwick1 is offline
Old 20-06-2008   #11
Trader Rating: (0)
Allright! Now we're getting somewhere So it could actually be the crank sensor then. It could be the origin of the light and wil ultimately resolve in no spark. I believe that is a decent theory
Fiat Punto GT
Old 20-06-2008   #12
Trader Rating: (0)
erm without having a look 840 ohms could well be quite correct
but crank sensors don't always fail electronically the magnets in them can become weak after a wile also
other things that can go wrong on early bosh injected turbos are the amp pack for the coil that controls it on the wing i believe or iner wing not sure
but i would say fr now as you light is on you best get it read buy a fiat dealer that should certainly guide you closer to the fault no point spending money on parts you don't need
also if someone tells you to keep driving with the light on please stop taking there advice on anything straight away if it was my car i would want to know why it's on straight away
Tags: , , ,
vB code is On
punto won't start no spark stos Punto > Technical 1 24-03-2008 21:30
what spark plugs, what spark plug gap dave Punto FAQs 0 15-02-2008 10:19
punto gt no spark help needed webhead Punto > Technical 2 04-01-2008 01:25
punto 1.1 no spark jamie1 Punto > Technical 2 07-10-2005 20:12
Punto spark plug TheCarInfrontIsA-JTD Punto > Technical 4 29-09-2005 18:58
