The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 26-03-2008   #1
Trader Rating: (0)
Cool Punto code reader
Hi
I have a problem with my steering on my mk2 1.9d, the light is on and the steering wheel is hard to move ie no power steering. In all the forums there is talk of getting the code from the ecu at a dealers but is that not a code reader that would do the same thing. I know that I would not be able to set the steering up if it needs replacing but I would be able to see the code. Anyone any ideas of a suitable reader?
pogo16769 is offline
Old 26-03-2008   #2
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: Punto code reader
unfortunally theres more to diagnosing a fault than just reading the error(s).
T14086 is offline
Old 26-03-2008   #3
Trader Rating: (0)
Me too !!
i parked up in town the other day started the car and the steering light came on , drove it home with very stiff steering. At first i thought it was my steering column but when i got back in it 'light had gone out !' and steering back to normal , not done it since and steering been fine.
I presume this is a faulty sensor as my crank shaft sensor went the other month and cut my fuel off ! got it replaced £70 diog charge and £30 for the sensor to be fitted so if the steering light comes on again thats what i think it will be.
fiat punto 1.9jtd 2000
fooboy is offline
Old 26-03-2008   #4
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 is offline
Old 26-03-2008   #5
Trader Rating: (0)
Cool Re: Punto code reader
Yes I know that there is more to fault found that reading a code, at work I can plug a laptop into the machines but not with a car, any error code that is in the ecu can not be seen without a code reader and one of these would be useful as a tool to use for fault finding. As I said, if the car needs to be set up than it would go to the dealer but to have to travel the 50 miles round trip to get a code out of the ecu, is to me a waste of time when I may be able to get a code reader for the car.
Sorry to go but dealers up here are not that many and the price they charge can be high.
Old 26-03-2008   #6
Forum Moderator
T14086's Avatar
Trader Rating: (0)
From memory I think you can extract 2 EPS codes with a aftermarket code reader. Many errors are manufacture specific only 'extractable' with dedicated diag equipment.
T14086 is offline
Old 28-03-2008   #7
Trader Rating: (0)
Yep, if it's a steering fault you're wasting your time buying a code reader, it won't tell you anything unless it's engine/emissions sensor related. The proper fiat diagnostics costs around £2,500 because all the software's specifically designed for the fiat.
If you still want a fault code reader, this will work: http://www.ecufix.com/shop/index.php...roducts_id=197
The generic fault codes relating to steering are:
P0550 Power Steering Pressure Sensor Circuit Malfunction
P0551 Power Steering Pressure Sensor Circuit Range/Performance
P0552 Power Steering Pressure Sensor Circuit Low Input
P0553 Power Steering Pressure Sensor Circuit High Input
P0554 Power Steering Pressure Sensor Circuit Intermittent
And since the punto doesn't use hydraulic power steering, you're not going to have any of those sensors.
Mr Wild is offline
Old 20-06-2008   #8
Trader Rating: (0)
Red face Re: Punto code reader
Does anyone know where the diagnostic test port is and can i use a universal faulty code reader on it, if not what can i test it with on a Fiat Punto 55s 1997
martin5300 is offline
vB code is On
Error code reader? Alan Pritchard Barchetta 20 11-03-2008 08:50
MK1 punto fault code reader Spentona Punto > Technical 4 06-03-2008 17:33
Code reader sw83 Punto 1 28-09-2007 09:52
Engine code reader scouseman Ulysse 1 08-09-2007 12:53
punto 1.2 2004 code reader help pushthepunto Punto > Technical 4 23-07-2007 14:24
