The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 13-02-2008   #1
Trader Rating: (0)
Coolant level dropping ??
Hullo folks, I know this may have been covered before, but I can't work out a cause. My coolant level is dropping about 1/2 inch after a run, but there are no leaks, the head gasket has recently been done, and the car shows no signs of the new gasket leaking.
Could it be just an airlock somewhere? I'm a bit baffled really.
Thanks for any help
oddnumber is offline
Old 13-02-2008   #2
m_aver_ick's Avatar
Trader Rating: (0)
Re: Coolant level dropping ??
just leave the reservoir cap off for bout 5/10 mins with the engine running play with your hoses a little it should sort it if its an air lock,
thats what i do egvery couple of days if mine leaks to much
CAUTION, i may talk crap
w/2000
1.2 8v elx
m_aver_ick is offline
Old 13-02-2008   #3
FIREsporting's Avatar
Trader Rating: (0)
FIREsporting has donated! United Kingdom
you probably need to bleed the cooling system, it may be a air lock in the radiator causes pressure that prevents the thermostat from opening.
FIREsporting is offline
Old 14-02-2008   #4
Trader Rating: (0)
Thanks very much for the replies folks - reckon there is an airlock somewhere, I went out this morning and the level had risen slightly. I'll bleed it over the weekend
Unfortunately my relief at avoiding a hefty bill was short lived when I realised my clutch is on the way out
Old 14-02-2008   #5
aaron_uk's Avatar
Trader Rating: (0)
Just so you know, bleeding the radiator takes 20min to half hours tops. I'm currently trying to solve a cooling issue in mine. I did mine one evening, it's really quick and easy so it can be done one evening for testing the next day.
aaron_uk is offline
vB code is On
Coolant Level And Mix tgreenwood2 Punto > Technical 3 06-09-2006 17:47
Coolant Problem fishingpaul Punto > Technical 14 05-09-2006 19:03
Coolant Level - 95 Ulysse Alanovich Ulysse 0 17-07-2006 08:53
Coolant level HornetUK Punto > Technical 7 01-05-2005 22:34
Coolant level dropping rapidly... Sando Cinq/Sei > Technical 5 05-01-2004 19:22
