| condensation in headlight hi i noticed today that one of my headlights has condensation in it, i dont know anything about cars so can you give me some tips on how to sort it out please, a step guide is needed for me lol, i have a 2001 punto
| Shropshire UK | Re: condensation in headlight Doesnt really need a step guide, your looking for a water entry point, this can be anywhere! Start off with the rubber cover at the back of the bulb fitting point, is there one? Has it got holes in or is it loose? If all is ok you may have a hairline crack in the lens or lamp body within the car mounting point. Its caused by water getting in and not being able to escape it condenses into mist which you see.
| | #3 | ||
| Re: condensation in headlight ok i will go out now and have a quick look,
| | #4 | ||
| Re: condensation in headlight i have just gone out and had a quick look the light does not move/loose cant see any cracks, theres only a little bit on condensation in there at the moment,
| | #5 | ||
| Shropshire UK | Re: condensation in headlight Any discoloration of the reflector? I guarantee there is a water entry point somewhere! Maybe source a good lamp unit from a scrappies but you need to take care.
| | #6 | ||
| Re: condensation in headlight mk2 punto's have condensation in and can be solved by drilling holes in the back cover of the light which will remove any of the condensation, another way wud be to put some silca gel bags in the back of each headlight this should hopefully sort it.
| | #7 | |||||
![]() the silica gel I understand, but wont the holes let more moisture in? Headlamp units should be totally sealed.
| | #8 | ||
| (I Love Brackets) | Re: condensation in headlight apparently put one of them silicon bag things u get in shoe boxes by ur headlight and it will stop it. i read this sumwer i fink. Might of been nuts magazine lol so u may want to ignore that post ![]() | ||
| | #9 | ||
| Re: condensation in headlight I've drilled holes in the top of the casing, and placed silica bags OVER the holes.. worked perfectly.
| mk2 headlight condensation | pop | Newbie Central | 4 | 10-03-2008 20:11 |
| condensation in headlight | fletcher11 | Lets Talk FIAT | 6 | 12-02-2008 14:30 |
| Headlight reflector... | 1986Uno45S | Cinquecento / Seicento | 2 | 15-12-2007 11:55 |
| Headlight adjustment motor | TheCROW | Bravo/a > Technical | 2 | 22-05-2006 08:25 |
| Condensation in Headlight | Quarrybaby | Punto > Technical | 8 | 25-05-2005 14:16 |
