| | #17 | ||
| Bravo 1.8 HLX FTW | Re: not good blitzed through a very big puddle. sump was probably on it's way out then puddle has knocked a big rusty hole it it probably doing a little more than 30 mph i thinks this would then rapidly fill the engine with water from under neath and it would end up goin in to the combustionchanbers thou the crank case breather system and inlet manifold what you think because the air intake is high up and aboth the wheel arch area an ould never take in any water unless you get any squirting round the back of the light but that would be a major ford surely | ||
| | #18 | ||
| Re: not good blitzed through a very big puddle. ok ive had a look under the engine.. theres 3 fairly big holes in the sump.. it was full with oil and water! can i remove the sump without removing the gearbox! by looking i can only see that i have to remove it! grrr xD something has severely damaged the sump as there is one hole about an inch long
| | #19 | ||
| Re: not good blitzed through a very big puddle. lol major ford!! you should ave seen the size of the puddle! it came passed my wheels
| | #20 | ||
| Re: not good blitzed through a very big puddle. sump was probably on it's way out then puddle has knocked a big rusty hole it it probably doing a little more than 30 mph i thinks this was not the case
| | #22 | ||
| Re: not good blitzed through a very big puddle. sorry mk2 punto x reg 5 door elx! also the holes in the sump were caused by something big not water making holes or knocking out rusty holes.. they are tare marks in the metal and it has folded back... fresh silver marks thanks
| | #24 | ||
| Re: not good blitzed through a very big puddle. if my battery is out the car for a long period of time will my immobiliser still be sync'd with my key? thanks
| | #26 | ||
| Re: not good blitzed through a very big puddle. woop woop!! stripped the engine and i need a conrod! that was all the damage xD snapped and bent it lol.. anyone know where i can get a gasket kit, conrod, oil sump and new cambelt for my punto mk 2 1.2 cheers guys xD
| | #27 | ||
| Kills Threads | Re: not good blitzed through a very big puddle.
__________________ ![]() Fiat Punto Active Mk2B- 1.3 Mjet - Jet Blue | ||
| K&N any good? | si_ng23 | Leisure Lounge | 7 | 16-08-2005 13:35 |
| Good Fiat Dealers.... | stevejowen | Garages | 6 | 08-12-2004 22:45 |
| The Good & The Not So Good... | rriggs | Garages | 0 | 31-08-2003 21:55 |
