The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Become our fan on Facebook
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 19-12-2007   #1
Creaking Rear Suspension
My 1.2 8v Active has suffered from creaking suspension from almost new. The garage said that this was entirely normal and lubricated the rear suspension bushes regularly. This hovever only lasts for a short time until the noise is back.
As I understand, grease can have a detrimental effect on rubber and promote premature wear. What lubricants are the preferred ones for doing this job and which bushes should be lubed?
Also, does anyone have experience of a more permanent solution to this problem?
2003_Punto is offline
Old 19-12-2007   #2
Re: Creaking Rear Suspension
Id of said new bushes to fix the problem, i know someone who is having the same problem but wont replace the bushes for some reason.
Shaunyboyuk is offline
Old 19-12-2007   #3
I could understand replacing the bushes on an older higher mileage vehicle. But this has been going on since the vehicle was a matter of months old. Whilst it was under warranty, the dealers explanation was that they all do it and lubrication is the way ahead.
I was somewhat sceptical that once out of warranty, the story may change and all of a sudden they need replacing. But the noise is no worse than it was 30,000 miles ago and it does respond to lubrication. I just wish to prolong the life of the bushes by using the correct lubricant.
Old 19-12-2007   #4
Forum Moderator
T14086's Avatar
T14086 has donated!
try greasing handbrake cable holders at rear of car(look underneath).
T14086 is offline
(G) rear suspension jasonp Punto 9 04-09-2008 17:50
(G) Steering link knocking, rear suspension squeaking, etc. Tomasso Marea 12 09-08-2007 09:51
(G) Creaking from drivers side rear suspension philster Bravo / Brava 2 03-01-2007 09:12
(T) Rear Suspension theskiprat Cinquecento / Seicento 7 27-02-2004 18:21
Copyright ©2002 - 2010 FIAT Forum
