The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 30-09-2007   #1
Trader Rating: (0)
power failure?
I own a Punto active 8V (2005). This is my problem: A few times my car had a power failure without any specific reason for example: I`m driving the car normally and then I stop the car and turn down the motor and lock the doors. After one or two hours when I try to open the door I noticed that my central lock doesn't work (it is out of power) so I M oppening the door one by one, and the clock on the dashboard is blinking 0:00 like it has been cut out from the batterie. When I turned the key to give a contact all the light symbols on the board display doesn`t work like there is no power at ALL. Then I turn back the key and after a minute or two I try again and suddenly everything is back to normal. After maybe a few days or even weeks of normal work the problem is back again.Ther are some strange things happening (strange to the authorized service) like during a drive the back wind shield is starting to work without it has been turned on, or the central lock is going on and off during a drive all by itself. The problem repeats all the time but it doesn`t stays long enough so the people in the service can`t solve it(because until I bring the car in the service the problem is gone and everything is back in normal). Please help me with some ideas and suggestions!
vasebungurdziev is offline
Old 01-10-2007   #2
Grumpy Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Re: power failure?
Is it not under warranty?
Check battery terminals (disconnect battery to reset body computer) ...could be bad ignition switch aswell.
IF YOU'RE HERE TO MOAN OR SLAG FIATS - DONT BOTHER!
T14086 is offline
Old 01-10-2007   #3
Trader Rating: (0)
Re: power failure?
I have tried with the battery terminals but they are tight enough. Can you explain me what kind of part is the "ignition switch" and what is its role.{(I have tried to provoke the same effect(by touching the battery terminals like there is a bad contact) but nothing happened.}
(T) MK2 Power Steering Failure SteveoBN2 Punto 15 01-12-2007 18:22
(G) MK2 Punto Sporting Power Steering Failure deeinlondon Punto 1 08-01-2007 07:10
(T) New Punto Power Steering & Engine Management Fail shotter Punto 17 30-12-2006 12:45
(G) fiat punto power steering failure Chigsta2001 Punto 4 03-02-2005 10:38
(T) Car Security Failure juan Stilo 1 06-06-2004 00:22
