| punto revs surgeing hi , when i let my car tick over the revs are surgeing , does anyone have any idea what this could be , thanks alot by the way it is a 2001 sporting 1.216v thanks alot for help
| Re: punto revs surgeing I have a similar problem with my mk1 sporting, I believe it is called 'hunting' (i think) Never found a cure for it, after endless searching.
| | #3 | ||
| Pirates > Ninjas | Re: punto revs surgeing My 1.1 had it...believe it was caused by a dodgy ecu (i couldnt get it changed because i didnt have a red key so lived with it) thankfully the ecu seemed to use windows 95 cos like all M$ problems you could solve it by switching it off and then switching it back on again or you could put your foot on the brake then manually set the idle with the clutch then after a couple of seconds of that if you dipped the clutch it would hold steady after that but not good for your clutch or drive train, my 1.1 was expendable note the sig. | ||
| | FiatStiloJTD | Punto | 543 | 06-06-2008 17:15 |
