| Removing wiper arms My punto has suffered the typical wiper bush failure. To do any kind of fix I need to get the wipers off so I can take the linkage assembly out. I've followed the instructions in haynes and undone the bolts for each wiper and for the life of me cannot remove them. What am I missing here?
| | #3 | ||
| Re: Removing wiper arms Humm I'll keep trying then. I'm just a bit worried about breaking something. Thanks for the link. I was thinking more along the lines of drill hole/put in a pin rather than a £65 fix though!
| | #4 | ||
| __________ | Re: Removing wiper arms
__________________ Binki | ||
| | #5 | ||
| Re: Removing wiper arms Thanks, I missed that. Looks like a quality fix. To fit this I assume I will still have to remove the wiper assembly?
| | #7 | ||
| Forum Moderator | Re: Removing wiper arms penetrating fluid or good old wd40 helps,wiggle them to & fro & they will eventually come free..........mind the windscreen they break easily...talking from personal experience here
__________________ IF YOU'RE HERE TO MOAN OR SLAG FIATS - DONT BOTHER! | ||
| | #8 | |||||
I am assuming that the wiper arm is a splined fit so any pulling/wiggling should not include any rotation
| | #11 | ||
| Re: Removing wiper arms In the past, I've had to use a two-legged puller to get the stubborn buggers off!
__________________ I don't mind being wrong, but I hate it when somebody else is right. | |||
| | #12 | ||
| Re: Removing wiper arms I had the same problem. Someone glued the covers on so I couldn't get them off at all. I put the wipers on and switched the engine off when they were mid swing. That exposed the bushing. Drill with a long drill bit and pin it with a bolt and two nuts tightened against each other. I put some tape to stop them coming loose but they haven't needed it. Only problem is the wipers only swing 90 to 95% of what they did at the beginning. Saved a good bit of cash though. Didn't have 30£ fixes when my bushings went.
__________________ Me gasket be a blowin' Me coolant overflowin' Garrr! A punto life for me! | |||
| | #13 | ||
| Re: Removing wiper arms im cheaper again 2 jubilee clips less than a quid held for three years but its noisy(you get what you pay for)
__________________ CAUTION, i may talk crap w/2000 1.2 8v elx | |||
| Tags |
| arms, wiper |
| Wiper Arms | the frog | Multipla | 3 | 08-08-2007 09:20 |
| wiper arms | donaldmaclennan | Ulysse | 5 | 20-01-2007 23:41 |
| | Argonought | Stilo | 9 | 29-06-2006 19:47 |
| wiper Arms | WyattsMoma | Tipo | 2 | 21-01-2005 05:55 |
| | 4dog | Uno | 6 | 02-04-2004 17:33 |
