The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 23-09-2007   #1
Trader Rating: (0)
help urgent! fans/blowers/heaters/lights ALL GONE!
OK HELP!! Iv been taking my center console of a couple of times lately to look where my cd changer wires go etc. iv put it back on and I noticed the lights didn’t come on by the fans temp/blowers speed (but coz it was night time and I had music on I thought the fans were working) got in today to go a drive and NOTHING! NO FANS NO BLOWING NO HOT NO COLD! ARGGH! Iv checked what I think are the fuses for the fans and they look alright?
DO YOU THINK I COULD HAVE UNPLUGGED THEM BY ACCIDENT? AND IF SO WHERE WOULD THE CONNECTOR BE TO PLUG THEM BACK IN?
Many many thanx in advance!
Oh and everything else is working fine by the way!
fellowsuk is offline
Old 23-09-2007   #2
Trader Rating: (0)
Re: help urgent! fans/blowers/heaters/lights ALL GONE!
anyone? its freezing in my car?
Old 23-09-2007   #3
scoused out FTW!
Trader Rating: (0)
-DrEw- has donated!
it sounds like youve forgot to plug them back in lol, if not check fuses, if not wear a jumper lol
Yellow GP 1.4 '58' plate
-DrEw- is offline
Old 23-09-2007   #4
Trader Rating: (0)
but where do they plug in? i dont remember unplugging anything!
iv checked fuses everything is fine
Old 24-09-2007   #5
Banned
Trader Rating: (0)
dan_in_darlo has donated! United Kingdom
could be a lose connection try moving the wires around mate
if not wrap up for the winter lol
dan_in_darlo is offline
Old 24-09-2007   #6
Trader Rating: (0)
oh thanx! so know one knows where the wires connect? or what colour they are would be usefull, or any help apart from "wrap up warm" would be very welcome!
Old 29-09-2007   #7
Trader Rating: (0)
? no more pearls of wisdom then?
Old 29-09-2007   #8
Stripped
unonumero's Avatar
Trader Rating: (0)
Drives:
unonumero has donated! United Kingdom
check the wiring at the lighting? i dont have punto but it may be a dodgey earth? if you have a multimeter check that there is any volts at that part of the wiring. for it too work u need a closed circuit, check that everything is wired up correctly and has a power supply (multimeter) and is earthed
Uno: 16" Alessio Monzas, Toyo Proxes, -35mm Lowering Kit, 3.5" Peco, De-Locked, Recaro Seats, Stripped, Induction Kit, Wide arches, Clifford G5
unonumero is offline
Old 29-09-2007   #9
Trader Rating: (0)
i have the same problem try moving the wires buy the heater matrixs and it may work mine did but i still get da problem and i found that the multi block that goes to da speed risister one side is earth and the other side should be earth but its live.if you do find out wat the problem is please let me now thanks
lewe is offline
Old 30-09-2007   #10
Forum Moderator
T14086's Avatar
Trader Rating: (0)
T14086 has donated! United Kingdom
Check the multiplug which is hooked up to the heater blower moulding nearest side to passenger door.Its a 4 wire plug & the earth (thick black) often melts (bypass this wire) causing symptons you both describe.
IF YOU'RE HERE TO MOAN OR SLAG FIATS - DONT BOTHER!
T14086 is offline
Old 02-10-2007   #11
Trader Rating: (0)
ok sound, unplugged and plugged in everything down by the passenger footwell, and now THE FANS AND HEATERS ARE WORKING! however the lights still aint working? now why would that be?
Old 02-10-2007   #12
Bravo 155 HGT
Trader Rating: (1)
mountainmachine has donated!
Becuase you havent switched your sidelights on?
mountainmachine is offline
(G) windscreen (urgent, urgent) bigpigeon2004 Cinquecento / Seicento 4 08-11-2005 13:30
