The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 06-08-2007   #1
theviper's Avatar
Trader Rating: (0)
mid rev range
this is doing my head in now i have changed the HT lead, plugs and fuel filter but still the same :-(
at low revs and high rev the car is fine as soon as it gets to mid rev's it will not pull at all
any ideas will really help as wife loves the car but will not drive it till i have fixed it
thank's Pete
theviper is offline
Old 06-08-2007   #2
I Am Legend
Punto.Power's Avatar
Trader Rating: (0)
Punto.Power has donated! United Kingdom
Re: mid rev range
Could may be the lambda sensor on its way out?
Fiat Punto Mk2 1.2 8v
Fiat Bravo 120T Dynamic
Punto.Power is offline
Old 07-08-2007   #3
littlepip17's Avatar
Trader Rating: (0)
Re: mid rev range
does it do it from cold if it does this rules out lambda cos it is open loop for quite some time until the car is warm
short of that it could be any sensor on the engine really
could be a problem with the throttle potentiometer also
could go to local garage and try different rmp's on an emissions tester and see if it's far away from were it should be
littlepip17 is offline
Old 07-08-2007   #4
theviper's Avatar
Trader Rating: (0)
Re: mid rev range
no it only when it warm's up
Pete
theviper is offline
Old 07-08-2007   #5
meow
beau's Avatar
Trader Rating: (15)
beau has donated! United Kingdom
Re: mid rev range
well go buy a new lambda sensor then
1993 Uno Turbo / 1995 Punto 55 / 2000 Punto jtd
beau is offline
Old 07-08-2007   #6
theviper's Avatar
Trader Rating: (0)
Re: mid rev range
is it best to go back to fiat's or would an after market one be fine (ie from Halfords, motorworld etc)
Thank's
Pete
theviper is offline
Old 07-08-2007   #7
I Am Legend
Trader Rating: (0)
Re: mid rev range
I would think your better going to Fiat than using an aftermarket one, http://www.shop4parts.co.uk/ they do the lambdas for under £60, also remember to reset your ecu once you replace the lambda..
Old 07-08-2007   #8
theviper's Avatar
Trader Rating: (0)
Re: mid rev range
how is that done ???
Pete
theviper is offline
Old 07-08-2007   #9
meow
beau's Avatar
Trader Rating: (15)
Re: mid rev range
Pete
disconnect battery for a while, over night if you can to make sure, but few hours should be ok.
beau is offline
Old 07-08-2007   #10
theviper's Avatar
Trader Rating: (0)
Re: mid rev range
Thank's all
i will let you know how it gose
Pete
theviper is offline
Old 07-08-2007   #11
Trader Rating: (0)
Re: mid rev range
after you replace a lambda sensor and the engine has gone thou a warm up cycle it should automatically turn the light off but the fault will still remain in the ecu as an intermittent one only fiat examiner or some other code readers can clear this but it doesn't really matter what you care about is that the light is off
yea more likely a lambda as everyone says if only when warm ie lambda closed loop
cheap-o lambda sensors are a waste of time I haven't seen any last more than a couple of years also with the original part you don't need to mess with wiring it to the original wires you just get new one and plug in it's under the cover at the back of the engine
vB code is On
mid speakers (god im a forum whore!) KG87 I.C.E 5 11-06-2007 23:38
Punto mk2a Rev Counter... fannon Punto > Technical 0 28-02-2006 19:03
Mid range in a cinq? arc I.C.E 5 25-06-2005 22:01
No mid range or not a lot gligsy_2000 Bravo/a > Technical 1 16-09-2003 20:48
