The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 06-08-2007   #1
Trader Rating: (0)
Exclamation Clutch Problems - Now Fixed
I’m new to this forum, so I thought that I would drop you all a little line about the fun and games I’ve just had with my Mk 1 Punto 85 SX.
A couple of weeks ago my clutch pedal started clicking around the biting point (as if it was catching on car mat, but wasn’t).
I lubricated the pedal fulcrum but with no improvement.
After about a week of driving the clicking disappeared but the biting point moved to about 2-3mm from the floor and it became very difficult to change gear.
My first thought was hydraulic problems/failure. I had changed the slave cylinder approx 1yr ago – common problem. This was all fine, so I bled the system. No air bubbles present and noticed full travel on the actuating arm.
Therefore problem had to be clutch thrust release bearings. Local independent garage wanted approx £350 inc.VAT ; FIAT quoted £400 – 500 (said it was a 4-5hr job).
So I used Mr Clutch in Aldershot, Hampshire, they changed the whole clutch mechanism within 2hrs and charged £201.24 inc.VAT + 2yr/20,000 mile warranty.
It turned out to be a very sorry looking thrust release bearing, the original clutch plate and pressure plate was still in good condition but was changed anyway.
They said this is a common problem on Fiat’s and mine was the third Fiat that day. They were very courteous and did a fantastic speedy job.
The moral to the tale, it pays to shop around – sometimes the cheapest option can be the best !!!
MK1 Punto 85 SX (16v)
jfindlay is offline
Old 06-08-2007   #2
Shropshire UK
Ffoxy's Avatar
Trader Rating: (0)
Ffoxy has donated! United Kingdom
Re: Clutch Problems - Now Fixed
Result!
FIAT quote
Local garage quote
Mr Cluth came thru, nice tip for those on the site and a good warranty too!
Ffoxy is offline
Old 07-08-2007   #3
littlepip17's Avatar
Trader Rating: (0)
there's no way it takes 3 to 4 hours to do a punto clutches there so easy
my dad did one in 1 hour 3 minutes last week
as for those quotes well over what most people get from fiat normally under 200
out of interest what dealer did you get them from
littlepip17 is offline
vB code is On
Gringing And Scraping Noise When Clutch Released Only Stops When You Depress Clutch allsortspete Punto > Technical 4 05-07-2007 20:45
Mr Clutch does it again! NumanR Garages 5 10-02-2007 17:16
Clutch / gear problems Dan_55 Cinq/Sei > Technical 2 29-06-2006 10:11
Changing hydraulic clutch gearbox to take a cable clutch? 4paws Uno > Technical 10 23-03-2006 14:56
Punto Mk3 clutch questions radicool Punto > Technical 2 19-11-2004 21:57
