The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 02-08-2007   #1
home_slice's Avatar
Trader Rating: (0)
Poor Emissions (from car)
Ok MOT day today and it failed on emissions
CO
should be 0.30 Mine 4.46
HC
should be 200 Mine 355
Lambda
0.97 1.03 0.897
Any ideas what could cause this? I know it could be a faulty Lambda sensor, but any other ideads? cat seems fine from outside... I have a Sportex Cat back but that shouldnt make a difference.
Broom Yellow Mk1 Sporting 16v
Multispoke 15's - Lowerd 40mm - Sportex catback - Pipercross Induction - Component speakers & 6x9's in custom boxes - Sub
home_slice is offline
Old 02-08-2007   #2
RA5 4LEX
Alex-R's Avatar
Trader Rating: (0)
Alex-R has donated! United Kingdom
Re: Poor Emissions (from car)
i know if a car has stood for a while it can affect it, if so take it for a long run.
2004 Fiat Punto 1.2 15" Ace 205 Alloys - CD/MP3 Player Sub + Amp - Remote Central Locking And Alarm - Tinted Rear Lights.
1989 Ford Escort RS Turbo Cabroilet, TurboSystems Chip, Phase 1 Turbo, RST Brakes, Electric Mirrors/Windows/Hood.
Alex-R is online now
Old 02-08-2007   #3
home_slice's Avatar
Trader Rating: (0)
Thanks buddy, but the car is used daily on long trips... ty
Old 02-08-2007   #4
I Am Legend
Punto.Power's Avatar
Trader Rating: (0)
Punto.Power has donated! United Kingdom
Hmmm apart from a faulty lambda, i know old spark plugs can give you poor emissions.
Fiat Punto Mk2 1.2 8v
Fiat Bravo 120T Dynamic
Punto.Power is offline
Old 03-08-2007   #5
Trader Rating: (0)
The list is long: poor spark plugs/coil(s), blocked air filter, poor compression, faulty lambda, ECU, sensors, injectors........
Suggest full service and test compression and also test lambda see http://www.picotech.com/auto/lambda_sensor.html
and
http://www.lambdapower.co.uk/
Good Luck
tinytim is offline
Old 03-08-2007   #6
Ralf S.'s Avatar
Trader Rating: (0)
It COULD be anything... but change the Lambada probe and enjoy a new world of emissions-reduced motoring.
Ralf S.
No bullets for chaingun
Ralf S. is offline
Old 03-08-2007   #7
home_slice's Avatar
Trader Rating: (0)
Thanks for the response guys, I checked one of the websites that Tim sugested and checked the lambda plug and that seems to be fine, also checked the spark plugs a few other things, got it booked in to have a new Cat tomorrow morning, so hopefully this will sort it.... will let you know.
Jack
Old 03-08-2007   #8
crabbo_1's Avatar
Trader Rating: (0)
I'm gonna go with cat is fubared. They don't last forever
crabbo_1 is offline
Old 04-08-2007   #9
home_slice's Avatar
Trader Rating: (0)
Well just replaced the Cat for the sum of £129 , and the emissions are still very high, it has reduced them a little but not enough to pass an Mot, Just looked up the Lambda sensor again and its a universal one, not a model specific one, so thats going in the bin and just ordered one for £55 from Rapid....
This is an expensive year for my car, what with new radius arms, exhaust, brake system and other misc things going wrong, at the moment im a very sad Fiat owner
Old 04-08-2007   #10
I Am Legend
Trader Rating: (0)
Oh that sucks, remember to reset the ecu once you fit the new lambda.
Old 04-08-2007   #11
home_slice's Avatar
Trader Rating: (0)
I would of forgot!!, Ace thank you.... Just have to work out how to Set up the Toad Alarm once the batterys dead
Old 07-08-2007   #12
home_slice's Avatar
Trader Rating: (0)
Just replaced the Lambda, and the batteries been disconnected for an hour now.... When i reconnect the battery, should i start and leave the car to idle for 5 mins for the ecu to figur out its tricks? or take it straight for a normal drive for 1/2 hour?
Iv been told different things?
Old 07-08-2007   #13
Trader Rating: (0)
Usual procedure is to let it idle upto temp (until the fan cuts-in), then go for a gentle 5 mile drive without using full throttle if possible to allow the ECU to learn the basic parameters using the Lambda/ knock sensor readings.
D4nny8oy is offline
Tags: , ,
vB code is On
I know lets all hate Fiat Bob in disguise Lets Talk FIAT 105 16-08-2008 18:52
Security Tips for your Car and Install The Devil Security 24 13-01-2007 00:07
soapy joes car wash is ace. thefishdude Leisure Lounge 2 13-01-2006 17:44
That didn't take long..................... spacecowboy Punto 50 12-07-2004 15:41
