| Speadgear just got a sporting speadgear, sometimes in reverse the engine cuts out? any ideas?
__________________ http://img69.photobucket.com/albums/...inqybanner.jpg | |||
| Re: Speadgear possibly the rear light's earth connection believe it or not when the reverse lights are lit they can confuse ecu's because of the bad earth's but other than this I don't know
| | #3 | |||
| Re: Speadgear
__________________ http://img69.photobucket.com/albums/...inqybanner.jpg | ||||
| | #4 | ||
| Re: Speadgear ill do a little research and see if i can come up with anything else
| | #5 | ||
| Re: Speadgear I had the same sorta thing, just need the throttle body cleaning out.
__________________ www.puntomk2.co.uk | |||
| | #6 | ||
| Re: Speadgear it never was a particularly good gearbox it was a joint development with fiat and subaru it is basicly a cvt gearbox only difference was fiat gave it the option of fully variable i.e. auto and 6 or 7 set ratios sequential I prefer the newer ones which have a manual gearbox run completely buy electro hydraulic systems they can change gear in a normal gearbox faster than I can ever thought about trading it in for one of the last of the 188s new if there are any left or a low mileage example might save you some expensive gearbox work just don't tell the garage you sell it to that it cuts out in reverse
| | #7 | ||
| Re: Speadgear
