| Punto Mk2 Brakes Juddering Hi all i have a punto mk2 3dr, and when i brake my front brakes judder, it feels like it might be a warped disc or maybe an ABS fault. does anyone have any suggestions on what else it could be or how to fix it, does it mean i have too get a set of new discs and pads. cheers
| I Am Legend | Re: Punto Mk2 Brakes Juddering Juddering through the brake pedal? Then yeah it will likely be the brake discs are warped, i had the same problem last year i didnt replace my brake pads even though people say you should when replacing the discs, that was 10 months ago still using the same pads lol but might be even one of your brake pads not in the right postion came loose.
__________________ Fiat Punto Mk2 1.2 8v Fiat Bravo 120T Dynamic | ||
| | #3 | ||
| Bravo 1.8 HLX FTW | Re: Punto Mk2 Brakes Juddering if there vented disks they can have this afect when thin you don't need to change brake pads when they are still plenty thick when you change disks but you do need to flat them with some sand paper to make sure they don't wear the disks unevenly
| | FiatStiloJTD | Punto | 543 | 06-06-2008 17:15 |
