The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Punto
Old 21-04-2007   #1
Trader Rating: (0)
rcarter has donated!
Bolts Stuck Front Shocks on Mk1 1999
I can not get the bottom bolts to move on the Shock to front hubs.
I have removed the nuts but with a 2 lb club hammer the bolts will not move, they seem to be stuck in the hub not the lower part of the shock, they will not turn or move. Any help most welcome, otherwise I think I am going to have to replace the hubs as well.
rcarter is offline
Old 21-04-2007   #2
__________
dave's Avatar
Trader Rating: (9)
dave has donated! Saint Kitts and Nevis
Re: Bolts Stuck Front Shocks on Mk1 1999
heat or take hub and shock off as one, grind the ends off then they often bash out ok
Binki
dave is offline
Old 21-04-2007   #3
just can't get enough
toad101's Avatar
Trader Rating: (0)
toad101 has donated! United Kingdom
had this problem on an uno removed hub and shock then bashed them out with a big mallet and lots of wd40, becareful where you do it though as we smashed the tiles on the front step of the house
toad101 is offline
Old 21-04-2007   #4
Trader Rating: (0)
Do you heat the whole thing, or just the bolts ?
rcarter is offline
Old 21-04-2007   #5
__________
dave's Avatar
Trader Rating: (9)
the hub bit that bolt goes through, care full you dont burn brake pipe or ball joint, drive shaft rubbers
Binki
dave is offline
Old 21-04-2007   #6
Trader Rating: (0)
I had the same problem, no amount of heat or belting it would remove them. In the end I grinded the head off the bolt so I could remove the shock and took the hub to an engineering place near me, only charged £10 to drill them out.
Make sure you copper grease the bolts up when you put it back together
DanGil is offline
Old 21-04-2007   #7
Trader Rating: (0)
Try grinding off the head of the bolt, the place somthing as a prop (screw driver) on the bolt which is jammed (now Headless) and give it a couple of hits with a hammer (or even mallet)... should pop right out!
samsonite is offline
Old 22-04-2007   #8
littlepip17's Avatar
Trader Rating: (0)
youl need a biger bar on that
littlepip17 is offline
Old 23-04-2007   #9
Trader Rating: (0)
What Bolts are they on Shocks on Mk1 1999
Can I replce these bolts with any good metric fine 10m or are these special?
My local deal wants £20.00 for 4 bolts, seems a rip off to me.
Does any one know what the spec of these are, are they 8.8 or someting stronger.
rcarter is offline
Old 23-04-2007   #10
__________
dave's Avatar
Trader Rating: (9)
Re: What Bolts are they on Shocks on Mk1 1999
they are special, where is dealer ask for fiat forum discount and say you will give them a good plug on here for it but that is the going rate
Binki
dave is offline
Old 24-04-2007   #11
Burninator of threads!
faster4_tec's Avatar
Trader Rating: (0)
faster4_tec has donated! Mongolia
if you haven't cut them off already you needn't.
get a big feckoff flat headed screwdriver, then jam it into the bolt head and you want to rotate the big bolt (you've removed the nut right?) anti clockwise whilst using the screwdriver to lever it out.
once its more than half way out it should just come out by hand or with some mole grips and more levering (you have to remove wrench before you pull it all the way off, otherwise you won't be able to get wrench off as it'll be stuck inside wheelarch ).
you can use the same technique for a lot of different things to do with big stiff bolts
Volvo for Life
faster4_tec is offline
Old 24-04-2007   #12
Trader Rating: (0)
Well, none of the above would work for me so some must be worse than others.
DanGil is offline
Old 25-04-2007   #13
Trader Rating: (0)
Tell me about it tried to do mine to replace suspencion and have ended up taking driveshaft off and removing bolt heads and tried all above with no sucsess and have managed to crack carrier and melt rubbers Now i have just brought new rubbers and have just brought new hub carriers with no seized bolts in so lets hope just need to get main hub bolt off each end only problem is that founrd out it is easier to do it when they are on car and mine aint F%£$ing hell !
Want to mod a punto is offline
Old 25-04-2007   #14
Trader Rating: (0)
if you got new hub carriers you'll have to get new (likely) bearings pressed INTO them (unless you have a bearing setting tool at home), as the old ones will fall apart if you try and pull them out.
Volvo for Life
Old 25-04-2007   #15
Trader Rating: (0)
I have found a supplier who does not rip you off like my local Perry's tried to, the bolts only cost me £1.69 inc VAT. Arrived in the post next day, supplier is Mangoletsi at Knutsford Phone No. 01565 722899 Ask for Steve.
For those who know about it, I checked Fiat ePER these blots know way sell retail at £5.00 each, so up yours Perry's ( they have done nothing but give Fiat an Alfa a bad name around here in more ways than one).
The spec of the bolts is metric fine 1.25 mm per turn, strength 10.9, (No. stamped on the head), the length 65mm, but 60mm is OK, that extra 5mm has no thread on it anyway.
rcarter is offline
vB code is On
How many Puntos are there on the Forum? - The Thread FiatStiloJTD Punto 543 06-06-2008 16:15
